whats the difference?
Old Dec 3, 2009 | 09:47 PM
Conanski's Avatar
Conanski
Actually the Lightnings were SD not mass air. But you're right it has the basis for a LOT more HP than a stock 5.8 truck motor so every little performance part added pays bigger dividens. And yes you can build one to match or beat it and you don't even need a 5.8 truck to do it, Lew52's GT40 headed 302 machine regularly beats stock Lightnings in the 1/4 mile, but it's got more cam, more gears, and a better exhaust system.
Old Dec 3, 2009 | 09:53 PM
TexasGuy001's Avatar
TexasGuy001
Originally Posted by 93 mix 'n match
well heres the deal. i know my budget isnt for an original lightning. i love the looks of it. so if there wasnt that big of a difference, i would take a standard f150 and make it look like one. id end up building up the 351 in it anyway so i guess that dosent matter. the interior and exterior not a problem. whats the deal with the frame being thicker? why would they do that?
I love the 1st Gen Lightnings too. One day I will have one. If you want to create a replica of one, that isn't too hard to do. My friend has a clone.
https://www.ford-trucks.com/forums/g...asonLewis.html
Old Dec 3, 2009 | 10:01 PM
rla2005's Avatar
rla2005
Wrong.....all Gen 1 Lightnings were Speed Density from the factory
Old Dec 3, 2009 | 10:02 PM
cjben's Avatar
cjben
Originally Posted by rla2005
FWIW here is a photo of my last Lightning I sold earlier this year:
It was customized by the previous owner
did you sell that on ebay? I remember seeing one like it earlier this year on ebay.
Old Dec 3, 2009 | 10:11 PM
rla2005's Avatar
rla2005
That was it
Old Dec 3, 2009 | 10:57 PM
97FRD1TN's Avatar
97FRD1TN
My mistake,I guess I just figured they mass air.
Old Dec 3, 2009 | 11:06 PM
TexasGuy001
I found it odd that SVT didn't make them mass air. I would have thought that they would have. There is a Ford Racing or Ford Motorsports mass air conversion kit that many 1st Gen Lightnings have been upgraded with.
Old Dec 27, 2009 | 03:50 PM
monkei's Avatar
monkei
Originally Posted by Conanski
Lightning has lowered suspension with oversized swaybars
What size is a front L swaybar? Do they not fit 4wd trucks?
Old Dec 27, 2009 | 11:39 PM
TexasGuy001
If you want a larger front sway bar, you can get one from Hellwig. Thats what I did.
Old Dec 27, 2009 | 11:50 PM
monkei's Avatar
monkei
Yeah, they don't list any (front) for a 4wd late model bronco. I'm wondering if/why the Hellwig p/n 7597 1¹⁄8” front bar listed for the "92-96 F150 Pickup with factory curved crossmember" wouldn't work? Don't the 4x4 Broncos and f150s of that year range (92-96) have the same front suspension/factory sway bar setup?
Old Dec 27, 2009 | 11:56 PM
Hitokori's Avatar
Hitokori
uhm... about all the suspension components for a f150 are the same as bronco.
Old Dec 28, 2009 | 12:03 AM
TexasGuy001
The Hellwig doens't mount the same as the factory sway bar does. It mounts the same in the middle but has its own brackets for the end links.
It mounts to the angled skid plate / steering linkage gaurd and then to the I beams. I don't see why it won't work on a Bronco. It probably would need differnt end link brackets.
Old Dec 28, 2009 | 12:29 AM
  #28
monkei's Avatar
monkei
Are you talking about a p/n for 2wd trucks?
Old Dec 29, 2009 | 07:09 AM
  #29
TexasGuy001
Yeah, but the Hellwig I saw for 4wd mounts the same. They may offer more than one though.
Old Jan 7, 2010 | 11:32 AM
  #30
monkei's Avatar
monkei
It mounts to the angled skid plate / steering linkage guard and then to the I beams.
Do you have any pictures of this? I don't believe I have this skidplate/guard on my Bronco....
Ken2600
33
Apr 17, 2023 11:07 AM
abosely
Nov 23, 2015 06:04 AM
Duder Lebowski
2004 - 2008 F150
Jan 10, 2015 08:15 PM
kuzco
Apr 24, 2012 05:27 PM
NW 150
May 12, 2010 09:57 PM
