Injectors Question
Old Dec 6, 2009 | 07:10 AM
dyoung14's Avatar
dyoung14
wait! what line did you change? did you change the injector hard line? if so did you use a 7.3 line? cause the 7.3 lines are longer than the 6.9 lines and that will change your timing on that one cylinder, you can swap lines betweeen both engines, but you have to swap all of the lines not one
Old Dec 6, 2009 | 06:25 PM
bad12jr's Avatar
bad12jr
I'll check tomorrow. I changed the orings today. No help. Im gonna inspect all my fittings tomorrow in the fuel system tomorrow. It runs great on bottom end. Just as not much top end power as it had when i first replaced it all.
Old Dec 6, 2009 | 06:27 PM
bad12jr's Avatar
bad12jr
I bet thats what it is. I bought a set off ebay. Good call man. it was a little different when i put it on but i thought nothing about it.
Old Dec 6, 2009 | 06:42 PM
bad12jr's Avatar
bad12jr
well i have a shot 5069 pump thats set outside for about 2 months because papaw thought it was trash. So its now nice and rusty. But i might see if i can get it rebuilt bigger. I couldnt see the numbers because of it being dark on the truck
Old Dec 6, 2009 | 07:34 PM
dyoung14's Avatar
dyoung14
if you swap the hole 6.9 lines it will work but it changes the timing on all the cylinders, which is just fine but when you have different cylinders with different timing then thats kinda funky
Old Dec 6, 2009 | 07:42 PM
bad12jr's Avatar
bad12jr
I think thats what it is. Ill have to get one from ford monday i guess. dang. i dont wanna swap all the lines.
Old Dec 6, 2009 | 08:05 PM
dyoung14's Avatar
dyoung14
its not a bad job, just pull the ip, i pull the ip now to do glow plugs cause it makes it so easy, and dont take me no time to pull an ip, i could have sold you some lines a while back for a dang good price, but another member on here is supose to be sending a money order for them
Old Dec 6, 2009 | 08:08 PM
bad12jr's Avatar
bad12jr
i know its not bad. I replaced the whole pump in the spring. just dont really wanna lol
Old Dec 6, 2009 | 09:08 PM
dyoung14's Avatar
dyoung14
lol well if you lived close i would do it for you
Old Dec 6, 2009 | 10:17 PM
bad12jr's Avatar
bad12jr
Well are the 6.9 lines smaller I.D. or the same as 7.3
Old Dec 6, 2009 | 10:23 PM
dyoung14's Avatar
dyoung14
not that i know of, im pretty sure the only difference is that the 7.3 lines are just a little longer
Old Dec 6, 2009 | 10:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Head design changes -
6.9 features "centered" glow plugs, while 7.3 are "off-center"
Injection nozzles have been retracted on the 7.3 .060" to facilitate Federal and state emission certs.
6.9 #1 cylinder line did not have the pulse adapter where the 7.3 line does, so it is the biggest difference in length, longer by the size of the pulse adapter.
If you happened to get an 7.3 E series line #4 is where the pulse adapter is on them for the 7.3 engine, so that line would be shorter than the one on the F series engine.
.060" is not very much and unless the line you replaced was on #1 or #4 I don't think that is your problem.
Old Dec 7, 2009 | 09:54 AM
  #28
bad12jr's Avatar
bad12jr
it was number two on the driver side. It seemed a little longer then the original.
Old Dec 7, 2009 | 10:16 PM
  #29
Dave Sponaugle
That would be cylinder #4.
There is also a possibility that someone installed an E series line without the pulse adapter on there before if you were not the original owner.
Every time I have changed injection lines, they are close, but not a drop on exact fit.
The all need a little tweaking before they fit just right.
Even if you have them perfect, change the IP timing 3/16", then unbolt the injection lines and see how wrong they fit.
