AAARG!!! Door handle!
Old Dec 3, 2009 | 11:37 AM
Fullcrew7.3's Avatar
Fullcrew7.3
I've broken SOOOOO many of these stupid door handles! Drivers door inside handle. I'm sure others have had this problem. What did you do to fix it???? I've tried shimming and extra support around the base, but thought I'd see what other guys have tried. Thanks
Old Dec 3, 2009 | 02:34 PM
rodneywar's Avatar
rodneywar
Mine kept breaking then i found out why the cable was cutting into the cable housing making it very hard for the cable to slide inside it so i replaced the handle assembly and havent broken one since..
Old Dec 3, 2009 | 02:38 PM
Copedawg's Avatar
Copedawg
I think NAPA has a metal one
Old Dec 3, 2009 | 02:39 PM
yoslick's Avatar
yoslick
Been driving for close to 40 years now both Fords and Chevys and have never broken a door handle (knocks on wood!!) However tail gate handles now thats another story!
Old Dec 3, 2009 | 02:43 PM
Copedawg's Avatar
Copedawg
Good thing you have a crew cab! You have a spare in the back
Old Dec 3, 2009 | 06:28 PM
ckal704's Avatar
ckal704
I broke one a ways back. I replaced it with a plastic one, but lubed the cables, etc inside the door with a little bit of silicone spray.
All has been well since. I think it has been about 4 years.
I wouldn't mind having metals ones, but I found a plastic replacement at the first stop I made (Autozone, I think) so I just bought it and put it in.
The nearest Napa is out of the way of my normal travels, but if I knew for sure they had metal handles, I'd make the trip.
Old Dec 3, 2009 | 06:49 PM
skidford's Avatar
skidford
just go to junk yard and get a set of metal ones for a couple bucks .im pretty sure any 80s will work.
Old Dec 3, 2009 | 06:57 PM
Fullcrew7.3
I went to the wreckers and got the last 2 in the whole yard. All the passenger side handles were there. Just not the driver's side ones. I noticed that the part of the door that the bracket attaches to is cracked and has a lot of play. That would make sense as it always felt like I had to pull it a lot farther than I should have to. I guess I'll just have to pull it all apart and fab something to brace it with before I bother getting a new handle. Funny stuff Copedawg (groan)........
Old Dec 3, 2009 | 07:06 PM
Copedawg's Avatar
Copedawg
My back door is missing one to this day!, lol. I took the monster in law last year for a ride and she thought I was some kind of control freak or something when I had to let her out the back like a a shcoffer.
Old Dec 3, 2009 | 07:30 PM
Fullcrew7.3
HA HA HA HA!!!!!! THat's hilarious!!!!
Old Dec 3, 2009 | 10:43 PM
MustangMatt96GT's Avatar
MustangMatt96GT
Ive broken 4 of them... and drew one up in Solidworks and am thinking of seeing what a machine shop would charge to make maybe 10 or so and either sell them or just make me two...
Ill check with napa for the metal ones first.
Old Dec 3, 2009 | 10:50 PM
Fullcrew7.3
Let me know the part number if you find it. I won't be able to get to my local napa until next Wednesday.
Old Dec 3, 2009 | 11:13 PM
nateairman's Avatar
nateairman
I broke lots of them when I first had the truck. Since then I have welded the cracked door up and lubed the cables. It has been a few years now and I am noticing it is getting a bit close to breaking again so I will go in and see what went this time. Most likely just need to put in a better support and relube the cables. It works to roll down the window and open the door!!
*2fords*
Jul 2, 2016 12:51 PM
neverdoneanoilchange
Oct 18, 2013 07:13 PM
fordor
Nov 23, 2012 03:23 PM
1320quick
Nov 12, 2010 03:43 PM
imlowr2
Mar 16, 2005 11:05 PM
