While driving my engine surges like there is vacume leak, the engine hesitates then power will come. When I pop the hood it does sound like a whine from the manifold area....I believe my gasket for my intake manifold needs to be replaced. Would this be a nightmare to do for a home mechanic? From what it seems lots of parts need to be removed.... ugh
I just replaced a head on a v-10 and the intake was very easy. You do not have to remove the water pump. But do follow the torque sequence for all the bolts.
Wow, that is a pretty big leap, from "my engine is surging and making a whining noise" to "I need to replace my intake manifold gaskets."
There are about 30 things I would look at prior to jumping in and replacing those gaskets, like torn or leaking vacuum hoses, bad sensors or a bad COP.
I think it took about 30 hours of dirty hands time to change out 1 head. I took my time and probably wasted 3-4 hours on stupid things like the fuel line connections at the rail.
If I had to do just the intake gaskets, I'd guess it would be done in about 3 hours.
I don't really recommend loctite as I think it impacts the factory specified torques.
