can a run ?
Old Dec 3, 2009 | 01:00 AM
ampslw's Avatar
ampslw
can a run ?
Can i use 0w30 rottila HD Blend in my 7.3 in the winter live in cold area
" Sorry bad spelling "
0w30 Rotella SYNTHETIC BLEND
Old Dec 3, 2009 | 06:18 AM
mueckster's Avatar
mueckster
Do you have the specs for this oil? Is is diesel rated? Many run the Rotella 5w-40 Synthetic and love it. I use it myself, though it doesn't get that cold down here. Upper 20's-low 30's.
Old Dec 3, 2009 | 06:52 AM
throwdown's Avatar
throwdown
Originally Posted by ampslw
Can i use 0w30 rottila HD Blend in my 7.3 ine the winter live in cold area
I'm not familiar with that particular oil, however, I live in Kitchener and run 5w-40 Valvoline synthetic all year round. It has worked well for me, but I am going to change to Rotella synthetic at the next change just to compare.
I would like to try Schaeffers but the local distributor has not been very helpful, and it's too expensive to order from the states.
The switch from dino oil to synthetic was like night and day for me when the weather turns cold.
Old Dec 3, 2009 | 09:57 AM
ampslw's Avatar
ampslw
more info on oil
2006 and older on-highway diesel engines CAT ECF-3, ECF-2, API CJ-4, CH-4, CG-4, CI-4 PLUS Shell Rotella
® T6 Full Synthetic 5W-40
Shell Rotella
® T5 Synthetic Blend Technology 10W-40, 10W-30,
0W-30, 0W-40
Shell Rotella
® T Triple Protection® 15W-40, 10W-30
MATERIAL SAFETY DATA SHEET
Revision Date: 02/13/2004
SECTION 1 PRODUCT AND COMPANY IDENTIFICATION
PRODUCT: ROTELLA® T SB SAE 0W-30
MSDS NUMBER: 400854E - 2
PRODUCT CODE(S): 50193
MANUFACTURER ADDRESS:SOPUS Products, P.O. Box 4453, Houston, TX. 77210-4453
TELEPHONE NUMBERS
Spill Information: (877) 242-7400
Health Information: (877) 504-9351
MSDS Assistance Number: (877) 276-7285
SECTION 2 PRODUCT/INGREDIENTS
CAS# CONCENTRATION INGREDIENTS
Synthetic Blend Motor Oil
Blend 50 - 59.99 %weight Synthetic hydrocarbon base oil
Mixture 30 - 39.99 %weight Highly refined petroleum oils
</PRE><HR>
<TABLE dir=ltr border=1 cellSpacing=0 cellPadding=7 width=719><TBODY><TR><TD bgColor=#ffcf00 height=12 vAlign=center>
Product Data Sheet from Shell Lubricants
</TD></TR></TBODY></TABLE>
</PRE>
SHELL ROTELLA<SUP>® T5TM 0W-30 SYNTHETIC BLEND TECHNOLOGY HEAVY DUTY DIESEL ENGINE OIL
RELIABLE LUBRICATION
LOW TEMPERATURE APPLICATION
Shell Rotella® T5 TM arctic blend Energised Protection TM oil has been formulated for excellent low and high temperature applications. Shell Rotella® T5 arctic blend uses a highly active additive technology enhanced with synthetic technology base oils that further energize the oil performance. Delivering responsive protection that continuously adapts to your driving conditions.
<TABLE dir=ltr border=1 cellSpacing=0 cellPadding=7 width=408><TBODY><TR><TD height=8 vAlign=center width="59%">PHYSICAL CHARACTERISTICS
SAE Viscosity Grade
</TD><TD height=8 vAlign=center width="41%">
T5 0W-30
</TD></TR><TR><TD height=23 vAlign=center width="59%">Kinematic Viscosity
(ASTM D445)
40°C mm2/s
100°C mm2/s
</TD><TD height=23 vAlign=center width="41%">
65.0
11.8
</TD></TR><TR><TD height=15 vAlign=center width="59%">Dyn. Index
(ASTM D 5293)
35°C mPa s
</TD><TD height=15 vAlign=center width="41%">
5680
</TD></TR><TR><TD height=8 vAlign=center width="59%">Viscosity Index
(ASTM D2270)
180
</TD></TR><TR><TD height=8 vAlign=center width="59%">Total Base Number
mgKOH/g (ASTM D2896)
</TD></TR><TR><TD height=8 vAlign=center width="59%">Sulfated Ash %
(ASTM D874)
1.2
</TD></TR><TR><TD height=8 vAlign=center width="59%">Density
@ 15°C kg/l (ASTM D 4052)
0.846
</TD></TR><TR><TD height=8 vAlign=center width="59%">Flash Point
(COC) °C (ASTM D92)
230
</TD></TR><TR><TD height=8 vAlign=center width="59%">Pour Point
°C (ASTM D97)
-51
</SUP>
Shattered
46
Sep 19, 2012 10:37 PM
EconolineFan
Dec 29, 2011 07:52 PM
kawa
1983 - 2012 Ranger & B-Series
15
Jan 20, 2010 12:29 AM
DVigeant
Oil & Lubrication
86
Dec 23, 2005 03:45 AM
shorthair
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Nov 1, 2005 08:15 AM
