engine ID?
Old Dec 2, 2009 | 11:34 PM
watt4's Avatar
watt4
engine ID?
I bought a 85 F250 that started out in life as a diesel. at some point before I bought it the diesel was swapped for a rebuilt gas engine-a 460 I think. How can I confirm the displacement? And how can I tell what year the original motor was built? Is there an ID number to be found somewhere? Any help would be appreciated.
Old Dec 3, 2009 | 11:10 AM
Kemicalburns's Avatar
Kemicalburns
get a haynes manual, it has pages on engine id by valve cover bolt and intake bolt numbers
Also pull a car fax on your truck Vin. you will find out a bunch.
Old Dec 3, 2009 | 08:31 PM
WhiteZombie's Avatar
WhiteZombie
google your vin number
Old Dec 3, 2009 | 09:55 PM
watt4's Avatar
watt4
thanks guys, I'll try your suggestions.
Old Dec 3, 2009 | 11:27 PM
85e150's Avatar
85e150
Look for casting numbers. That won't tell much, but will give an idea of the vintage. Look for numbers like those listed here.
Kelly hotrod - Ford Engines Page 2
(check page 3 for head casting numbers)
It is probably a 460, as they are more common and were produced later than the 429.
How is it for power? How does it run? What do you want to do with it, other than be able to buy the right parts now and then?
Old Dec 5, 2009 | 06:15 PM
watt4's Avatar
watt4
thanks 85e... I'm trying to find parts for it mostly. it's in good shape, and has lots of power, but I want to upgrade a few things.
Old Dec 5, 2009 | 06:22 PM
pintoches's Avatar
pintoches
If the engine was swapped how will checking the vin help tell what it is.
Old Dec 26, 2009 | 08:18 PM
watt4's Avatar
watt4
I found the casting numbers finally (can't always get to things right away). One on the block near the starter reads "D1VE". I can't see more without pulling the starter. Head number reads "D4VE-C1B". Does that mean I have a '71 block with '74 heads?
What does the "C1B" stand for?
77f250kid
17
Sep 1, 2017 03:19 PM
Devdye
May 19, 2016 11:00 PM
Tom Norton
29
Sep 19, 2015 08:26 AM
Resendiz
Aug 10, 2015 08:19 AM
diesel_73
Apr 2, 2009 12:27 PM
