banks pyrometer broke
Visit Harold G. Schaevitz Industries LLCTheSensorConnection.com Find more information about EGT Probes, LVDTs and related electronics <FORM id=searcharea method=get name=searcharea action=http://search.store.yahoo.com/cgi-bin/nsearch>
<FIELDSET><LABEL class=labelfield for=searchfield>Search<INPUT id=query name=query></LABEL><LABEL class=buttonlabel for=searchsubmit><INPUT id=searchsubmit class=ys_primary value=Go type=submit name=searchsubmit><INPUT value=yhst-54180625749471 type=hidden name=vwcatalog></LABEL></FIELDSET><INPUT value=http://tscsensors.com/egtdp072s072412.html type=hidden name=.autodone></FORM>
Home > EGT Exhaust Gas Temperature Probes > EGT Probes - Diesel & Biofuel > Diesel & Bio-Fuel Exhaust Gas Temperature EGT Probe, Straight
Regular price: $59.95
Sale price: $51.75
Availability: Usually ships the next business day.
<INPUT class=ys_primary title="Add to cart" value="Add to cart" type=submit><INPUT value=yhst-54180625749471 type=hidden name=vwcatalog><INPUT value=egtdp072s072412 type=hidden name=vwitem><INPUT value=http://tscsensors.com/egtdp072s072412.html type=hidden name=.autodone></FORM>
Product Description
• Enclosed tip sensing junction, ungrounded (Foul-Proof)
• Made in the USA
• Includes 316 SS adjustable compression fitting
• Stainless steel protected wires
• Inconel 600 sheathing for longevity at high temperatures
Specifications:
• Type K Thermocouple
• -148°F to 2372°F range (-100°C to 1300°C)
• Special Limits of Error accuracy (+/- 0.4% of reading)
• Probe diameter 3/16 inch (0.187 inch) (4.75 mm)
• Probe sheath is 4 inches (101 mm) long
• Stainless steel over-braid cable with Teflon™ insulated conductors, 6 foot (2 meter)
• Response time (300 milliseconds)
The Bio Diesel Exhaust Gas Temperature Sensor is specifically designed for use in Internal Combustion Engines operating on Diesel, Bio Fuels, LNG Injection Systems or any system using a sulfuric or exhaust systems that are prone to fouling EGT probes. This probe has been designed to withstand the rigors of marine and over the road trucking. It will also withstand the rigor of racing, tuning, and testing applications.
Made in the USA from superior materials, designed to withstand highly corrosive saltwater environments and even the most extreme racing conditions. The foul-proof sensing tip is recommended for EGT temperature measurements of sulfuric fuels such as diesel, bio diesel mixtures and LNG injection systems.
The Exhaust Gas Temperature Probe is capable of surviving extreme vibration and heat up to 2300 degrees F (1300 degrees C). The EGT probe will fit most diesel engine exhaust systems from approximately .750 inch diameter up to about 4 inch diameter with nominal installation modifications. The EGT probe is 0.187" diameter (4.75 mm) with a 4 inch straight sheath. An adjustable (316 Stainless Steel) 1/8" NPT compression fitting adapter is included. The EGT probe cable lead length is 6 feet (2 meters).
The probe cable is over-braided in stainless steel for heavy-duty abrasion resistance. The signal wires are Teflon insulated. Designed to deliver high performance, high temperature measurements, reliably and consistently in the most extreme operating conditions.
The high temperature sensors of choice for professional racing teams, R&D test labs, and Enthusiasts. The EGT probes can be used for many different applications, including… but not limited to… DHRA, Drag Racing, Diesel Sled Pulling, Road Courses, Tow Vehicles and Engine Management.
In stock and available for immediate shipment. We ship worldwide. IMPORTANT NOTE:
Please confirm with your instrument manufacturer that the instrument is compatible with a Type K thermocouple sensor.
EGT: Bio Fuel Diesel Exhaust Temperature Sensor From The Sensor Connection
Just check size with yours. They offer different diameters.
Check these guys out.
I don't see the type listed, you may have to call.
ISSPRO Product Categories
