I would like to get my truck up a bit higher than stock and run slightly taller tires.
My truck is a 2006 F250 Lariat Diesel crew cab.
I was thinking the 2" or 2.5" leveling kit for up front. What do you think of these kits? I had also read awhile back that the F350's run a larger block in the back. Is this true? How much bigger is it? Part numbers?
I plan on running the stock 18" Ford rims. What width are these? 7"?
What is the tallest 18" tire I can run stock and with the levelling kit?
Any pictures?
