Sponsored by: Real Truck
blowing fuse
Old Dec 2, 2009 | 12:18 PM
jb1965's Avatar
jb1965
Cool blowing fuse
anyone know why 10amp fuse keeps blowing? i have lights and radio and all, but none of my gauges work. could it possibly be a bad alternator?
Old Dec 2, 2009 | 12:37 PM
mackstruck's Avatar
mackstruck
The alternator will not blow individual fuses. You need to look in your owners manual and find out what system that fuse is for and give us more info. Then we can start the task of trouble shooting the system with you.
Old Dec 2, 2009 | 05:43 PM
Cowboy65's Avatar
Cowboy65
jb1965, welcome to FTE.
There are primarily three reasons why a fuse will open: overload, short circuit, and inrush current too high for fuse type.
You can evaluate the overload scenario by listing the current draw of everything on the circuit and making sure that it doesn't exceed the fuse rating.
You can use a multi-meter to determine if there is a short in the circuit. If it is intermittent then it can be a bear to track down the location.
The high inrush current scenario is a little tricky in that you have to make sure that the fuse type properly matches the starting current requirements for the devices on the circuit. For example a solenoid is a higher inrush device than a LED and therefore will require a different fuse type to carry the inrush current. Fuses are generally broken down in classes such as fast acting, slow blow, etc.
Old Dec 3, 2009 | 01:27 AM
wallz's Avatar
wallz
Check out this post and then check the wires under the steering column cover. (post # 31) They are known to short out and give all sorts of electrical problems. If that looks good, I would check the windshield for possible leaks on drivers side. That causes water into the fuse box area, that causes all sorts of bad stuff.
https://www.ford-trucks.com/forums/7...uestion-3.html
Welcome to FTE!
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Dec 14, 2009 | 10:12 PM
prolx's Avatar
prolx
im having this same issue also. I lose the instrument cluster, power door locks ,etc. Ive been trying to trace the problem but no luck as of yet
Old Dec 15, 2009 | 01:36 AM
redford's Avatar
redford
FTE Leadership Emeritus
Start with the basics. What fuse is blowing and what does that fuse power? This is important information to know, since you would not suspect the turn signals or turn signal wiring wiring if you keep blowing the horn fuse.
It could be a short to ground somewhere in the wiring harness of the items you listed or it could be a bad component (like the radio) drawing too much current. If you are not comfortable with tracing out automotive wiring (it can be very complicated) then take your truck to an automotive electrical shop for repair.
Stuck in germany
Jun 19, 2022 11:43 PM
fireeater91
29
Dec 31, 2019 03:05 PM
Surfcop
13
Apr 9, 2015 12:08 PM
Mark Wanless
37
Jun 4, 2014 01:38 PM
ralleyclimber
Apr 28, 2014 11:30 AM
