EEC IV into a dentside
Old Dec 2, 2009 | 11:05 AM
xkpsanit's Avatar
xkpsanit
Dont worry its a fast read...
proposed swap- 88 302 EEC IV powering a 79 F150 4X with a NP 435. Here are the small time issues I have encountered. This is just brainstorming for now. I dont have the motor set in yet. I need to acquire a 50 oz. flywheel, not a big deal. My stock clutch should fit on the new fly. I have yet to design a bracket for the mechanical clutch bell crank as Ford decided to omit that block casting in 80 or 81 I think. Does anybody make such an animal?? I have an auto donor truck that I am going to rob fuel lines, second pump, and rear tank from, appears to be a bolt in. Other small issues include power steering hoses but we can fab them locally. What I am looking for is pics of a clean modification to the firewall for the install of the ECM. I haven't decided how or where I am going to do it yet. And the only other concern is will this thing run without the VSS which is located on the rear diff. I have heard from a Ford turbo buddy that it will run fine. My 9" has a fairly fresh rebuild and I kindy wanna leave it under the truck. No woes on the harness mods, I have that fingered out already. I know this has been done I was hoping someone would have pics and share other issues they have encountered. Let us share our experiences...
Old Dec 10, 2009 | 03:17 PM
Beef Stew's Avatar
Beef Stew
I cut a small hole in my firewall to accept the big grommet on the wiring harness and I mounted the ECU in the glovebox.
Old Dec 11, 2009 | 10:22 PM
xkpsanit's Avatar
xkpsanit
I was thinkin of cutting a rect. hole and try to mount it similar to the 88 I pulled it from. I was just curious of a location to clear everything in-cab and I still wanna do a clean install. So you just cut a 2.5" hole and flopped the harness to the right side and pushed the connector through sideways with a grommet? I wanna do this on my 77 with A/C also. Looking for a win-win on both. I guess this would be the truck for trial and error. As it is only worth alot to me. i.e. she's not so pretty anymore. Any other issues in the swap I haven't mentioned. This would be an attempt at a 79 4x4 with no A/C and a NP435 four speed
Old Dec 11, 2009 | 10:32 PM
Conanski's Avatar
Conanski
Many of the earlier EFI trucks had a mechanically speedo which was driven from a VSS output on the transfer case or transmission tailshaft, and there were combo electro/mechanical versions of this VSS assembly that could be used for a retrofit like yours.
Old Dec 11, 2009 | 10:59 PM
xkpsanit's Avatar
xkpsanit
I am using the 79NP435/205. my buddy who is a turbo freak has used many harnesses in his swaps, including an EEC harness, mentioned he had no trouble runnin' w/o the vss. I guess I could try without and swap the rear housing in later if she don't run. It has 3.54 gears but high miles. as mentioned, I kinda wanna keep the nine
Old Dec 12, 2009 | 12:16 AM
Beef Stew's Avatar
Beef Stew
I have an AOD in my truck and from all the research I did it looks like the auto tranny setups don't need the VSS. I'm not using it and it works fine. However I think you do need it on a manual transmission. Something about stalling when you push the clutch pedal in? I'm not 100% sure but that's what I remember.
I just use my GPS as my speedo.
My 5.0 came out of a Mustang and I used the factory rectangular grommet that's already on the harness. I had to disassemble a few connectors and re-route them but it wasn't too difficult. The battery in my truck is on the passenger side and the Mustang as the battery on the driver side so I swapped all the power leads and ground over to the other side. No EGR, no evap, no air injection. All that stuff is gone.
Old Dec 12, 2009 | 10:12 AM
xkpsanit's Avatar
xkpsanit
the pass through on the truck is different, no grommet. and the ecu was located adjacent to the driver kick panel. I am goin to see if I can mount it vertical in same location and just build a cover. none of my trucks have those plastic vent thingys. I haven't seen them on anything newer than '76. Like I said, all I can do is try it, save the harness and swap the 8.8 in later if needed. I can live with 3.50/3.54 gear combo. so you have a speed dens stang 5.0 installed? you have any pictures? Did you put a pump in the tank or just suck it from the rail?
Old Dec 12, 2009 | 11:53 AM
Conanski's Avatar
Conanski
An efi motor will run without a speed input but it won't run to full potential, vehicle speed affects load and spark calculations so it does make a difference to overall performance.
Old Dec 12, 2009 | 01:29 PM
Beef Stew's Avatar
Beef Stew
My 5.0 came out of a '90 or '91 Mustang so it's a MAF setup, not SD. I added a sump to my stock in-cab fuel tank and mounted a Walbro inline pump on the driver side frame rail. Just do a search for threads I've started and you'll find my pics.
Old Dec 13, 2009 | 10:52 AM
xkpsanit's Avatar
xkpsanit
Nice pics and debate. ha ha If you have a little run after the the radius to the filter I don't think you ll have an issue. BTW you TIG better than MIG lol. Didn t see the the finished product, do I have to search more. Oh and what about that big block, "Gordy" needs a new motor too.
Old Dec 15, 2009 | 11:35 PM
Beef Stew's Avatar
Beef Stew
LOL thanks. Yeah I was pretty shocked that that was the feedback I got on my entire build. Not a question about wiring or the install or anything else. I get some random BS from some guy worried about my gas tank sump poking through the bottom of my cab. So weird. And yes, I hate MIG. Finished product is sitting in my driveway and I'm without a camera right now. I'll get some pics for you soon.
And in closing, I bought my 5.0 with AOD delivered for $700. I sold the 460 and C6 for $700. And I got the truck for free! Best deal I've ever had!
Old Dec 15, 2009 | 11:50 PM
xkpsanit's Avatar
xkpsanit
found a 429, nine miles away. ol man deceased and daughter needing money, but I been outta work for 14 weeks and askin' wifey for beer money. just gotta a job sloppin auto parts over the counter again but only been a week. cant go buying a motor now. tryin to get the motor in her escape and the Tbird just laid down. cant win. check out the pic in my gallery about my escape, craziest thing i ve ever seen. been tickin' for years and all these crazies here said it was the check valve in the filter. been there tried that... worse issues for me . me and bro just got the "new" motor bolted in. do not try that at home. not a good idea can't wait to get started on my 79...
Old Dec 16, 2009 | 12:02 AM
Beef Stew's Avatar
Beef Stew
Wow that's a bummer. What was the problem? It's kinda hard to tell in the pic.
Old Dec 16, 2009 | 12:09 AM
xkpsanit's Avatar
xkpsanit
It was RTV or an O ring "piece" stuck in the oil passage and starved the OHC. then the cam wore out the caps and caused more lash until the rockers just fell off of #6.
bozo4ford
1983 - 2012 Ranger & B-Series
Oct 6, 2012 07:47 AM
Jeff and Nicolle
Jul 11, 2012 06:10 PM
hayseedscout
Mar 8, 2012 11:21 PM
Oscar Meier
Sep 16, 2003 10:01 PM
restorit
Computer Chips & Tuners
Jul 20, 2003 05:33 PM
