Oil dipstick
Old Dec 1, 2009 | 11:14 PM
Vinford's Avatar
Vinford
Oil dipstick
2002 7.3
After I check my oil I have a very hard time getting my dipstick back in.
It was almost impossible last time , I had to use 2 hands and lots of pushing to get it back in.
Anyone?
Old Dec 1, 2009 | 11:19 PM
crazymut's Avatar
crazymut
I know it sounds wierd but try flipping it 180 deg. You would think it would go in up or down but they only want to go one way.
Old Dec 1, 2009 | 11:22 PM
Old and Busted's Avatar
Old and Busted
Mine is the same way. One way does go in easier.
I'm worried there's a small crack in the tube somewhere I can't see. I'm trying to delay replacing the tubing until when the pan has to be replaced. No leaks yet...knock on wood!
Old Dec 1, 2009 | 11:28 PM
crazymut's Avatar
crazymut
I think that is just the way they are made. Mine has always done that.
Old Dec 3, 2009 | 10:30 AM
Vinford's Avatar
Vinford
You guys say yours is also hard to get in?
How hard?
Mines almost impossible.
Like it can take 10 minutes of turning it around and pushing and pulling.
Im going to quit checking the oil it doesnt ever need any anyway.........................
Old Dec 3, 2009 | 10:50 AM
onelionhunter's Avatar
onelionhunter
Diptstick
Might take a look at where the bracket that holds the tube to the valve cover comes together and see if it was bent when someone pulled the valve cover.
I destroyed my dipstick tube when I pulled my valve cover, and i would suspect that yours may have been slightly damaged the same way.
I think the dealer quoted me 45 bucks for new tube and dipstick, i am sure ed could beat that. I got a used one for 10 bucks though.
Easy to replace, 1 bolt on the valve cover and it pulls right out of the pan, just an O ring on the bottom of the tube to seal it in.
Tom
Old Dec 3, 2009 | 11:00 AM
kevinwilly's Avatar
kevinwilly
When I bought my truck, the handle on the dipstick was broken off, so you could not put the dipstick all the way in without losing it.
The first thing I did was to buy a new dipstick, and out of the box it WOULD NOT go in all the way. Not even close.
I was frustrated, so I compared it to the stock dipstick. The factory one had been ground down a tiny bit at the tip. About 1/16" narrower for the length of about 1".
So i got out the 'ol angle grinder and made mine just a little bit pointier- not much, mind you, just a tiny bit, and holy crap- it goes in and out without any problem now.
I have NO idea what it was hanging up on, but it's way nicer now. I still have to use two hands, because otherwise it flexes too much, but it's not a problem at all.
Something to try....
Old Dec 3, 2009 | 12:22 PM
PaysonPSD's Avatar
PaysonPSD
Mine got to be a real PITA to push back in. I carefully pushed the top of the dipstck tube about an inch toward the firewall and now it slides in with ease. I think laying on top of the motor to work on it bent the bracket.
Old Dec 3, 2009 | 12:31 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
dipsticks are a PITA because of weird size/shape if I can fit it into a box UPS charges by the size and or weight and that screws up the price and might as well by local.
grrrrr
hosscat76
Oct 8, 2014 09:08 AM
Tigger!
20
Apr 15, 2013 01:15 PM
bigbubba87
Feb 28, 2011 10:36 AM
Vinford
Nov 1, 2009 10:16 PM
mike460
Sep 3, 2002 10:50 PM
