White Smoke
Old Dec 1, 2009 | 09:45 PM
mlynchnole's Avatar
mlynchnole
White Smoke
Hi, I've got an issue that I need some guidance with. I've got an '07 F250 Harley truck with a Volant air filter, a 5" exhaust with a 6" tip, and a Bully Dog Triple Dog Downloader. The engine is a 6.0 liter diesel.
The truck starts up okay, with no discernable smoke. When I drive for a couple miles and start hitting the stop lights, there's a decent amount of white smoke when at idle and immediately upon acceleration. Other than that, the truck runs great with no noticable power loss and she sounds like a "Harley" truck should sound. Although I've got the after-market power add-ons, I really don't run the engine too hard. I don't race it, etc.
I took the truck to a mechanic (non dealer) who thought that the issue might be turbo related. He didn't think that I had a head gasket issue (which was my original concern, given the white smoke). The mechanic also messed around with the Bully Dog and shifted settings back to stock. I downloaded all updates and hooked the Bully Dog back up. I noticed that I had the following diagnostic error codes: P0487 and P1000. I understand that the P0487 is related to the EGR Throttle Position Circuit Control. That being said, I was wondering why the mechanic might have been fixated on a potential turbo issue. I've just joined the forum, but I've read much tonight about EGR cooler and oil cooler issues causing issues similar to what I'm facing.
I've got a couple questions: what do ya'll think is the most likely problem that I have? Once again, the white smoke only starts once the truck is warmed up and is only noticable at idle and take-off. Also, will I have issues if I simply shift the Bully Dog settings back to stock and take it in to the dealer?
Thanks for your help.
Best regards,
Mike
Old Dec 1, 2009 | 10:05 PM
brickie's Avatar
brickie
Sounds like an egr cooler leak,smell the smoke if it reeks it is fuel if it is sweet it is coolant.Ditch the dog it will cost you your tranny over time.IMHO
Old Dec 2, 2009 | 06:49 AM
mlynchnole's Avatar
mlynchnole
Thanks Brickie. I'm pretty familiar with the smell.....more like diesel fuel than a sweet coolant smell. I've read similar posts about the Bully Dog on the 6.0. For now, I guess I'll switch the Triple Dog back to stock settings and get things in to the dealer. It appears as though Ford has many issues with the EGR. Do you think that they could legitimately claim that the EGR failure is a result of after-market installations (and attempt to not cover under warranty?). Thanks again, Mike
Old Dec 2, 2009 | 07:18 AM
bismic's Avatar
bismic
Ask around and try to find a "mod friendly" dealership BEFORE taking it in. Most dealerships are getting pretty picky about aftermarket mods (and you are heavily modded).
I would pull the EGR valve first and see how dirty it was. If you park at a downhill incline after driving it, you can check to see if you have any coolant in the intake (EGR cooler leak) under the EGR valve. Be prepared to clean the valve if it is dirty. The Tech folder has some good instructions. Mine was bad at 30k miles.
