changing differntail oil??
Old Dec 1, 2009 | 07:28 PM
tbenks's Avatar
tbenks
i have an 87 f250 that i recently purchased and when i went about looking for drain plugs on the front and rear diff i couldnt find any, i was told the rear axle was a sterling 10.25 not sure about the front, anyway is it nessecary to remove the diff covers completely to change the oil??
Old Dec 1, 2009 | 07:32 PM
94MustangGT's Avatar
94MustangGT
Yep, on the rear axle you will need to remove cover, but luckily it's not as messy as it sounds. Remove the spare tire to give you more room.
Old Dec 1, 2009 | 07:35 PM
tbenks's Avatar
tbenks
ok, do you know if i can re-use the exiting gasket, or will i have to find a new one?
Old Dec 1, 2009 | 07:38 PM
zxwut?'s Avatar
zxwut?
I always replace gaskets. Better than having to do it all over again later.
Old Dec 1, 2009 | 07:40 PM
94MustangGT
I use the hi-temp "form-a-gasket." $5-6 at the auto parts store. Just clean the surfaces well, and follow the directions on the tube of gasket maker. Don't forget the friction modifier additive if you have a limited slip.
Old Dec 1, 2009 | 08:01 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Like 94MustangGT said, use hi temp silicone. I use Permatex. For the front diff, use a suction gun to suck the oil out. Then fill it back up until it starts pouring out.
Old Dec 1, 2009 | 08:06 PM
tbenks's Avatar
tbenks
ok thanks, i think ill try going with that form a gasket stuff, dont really feel like tryin to find a new gasket if i dont have to, also, i picked up some lucas oil 80-90 weight stuff, that should be fine right?
