Up pipe leak
Old Dec 1, 2009 | 09:24 AM
superduty4x4's Avatar
superduty4x4
Up pipe leak
I've had a slight leak for a while now that seems to be getting worse lately. I already have all the parts to replace the gaskets and the O-rings in the turbo, but I can still build good boost (though not quite as good as it used to be) so I'm wondering if I should just hold out or go ahead and dive in... thoughts?
Old Dec 1, 2009 | 09:36 AM
mueckster's Avatar
mueckster
Go for it! As you said it's not getting any better. Are you going to reuse the stock uppipes and just replace the donuts? No bellowed uppipes?
Old Dec 1, 2009 | 09:54 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
It may buy you a little time, changing the donuts. If you plan on doing the bellowed up pipes later, this will give you good experience on taking the turbo and up pipes off.
Old Dec 1, 2009 | 10:02 AM
mueckster's Avatar
mueckster
That's why I asked. If you can hold out for the bellowed uppipes, I'd wait then and do it all at once.
Old Dec 1, 2009 | 10:16 AM
03_PSD's Avatar
03_PSD
I would only want to dig into this project once, I'd do the bellowed and be done with it.
Old Dec 1, 2009 | 10:40 AM
PwerStroke99's Avatar
PwerStroke99
Chase, just get your hands dirty for once and git r dun!!!! Damn!!!
Old Dec 1, 2009 | 10:44 AM
superduty4x4
STFU soldier boy!
Roland and Rick- I don't have the option of bellowed pipes on with my stock turbo, the late model bellows won't fit with my early bird turbo and I can't swing a turbo conversion right now.
Old Dec 1, 2009 | 11:08 AM
miller_feed
Originally Posted by superduty4x4
STFU soldier boy!
Thats right Chase, I forgot you came to the party a little too early. You got the early bird.
Old Dec 1, 2009 | 11:09 AM
03_PSD's Avatar
03_PSD
guess its donuts for you unless you feel its a great time to upgrade to 99.5..lol
Old Dec 1, 2009 | 12:06 PM
aldridgec's Avatar
aldridgec
You may want to consider replacing the pipes with new ones. I haven't priced them out though. My old gaskets had worn grooves into the pipes. I used over sized gaskets with lots of anti-seize but they are leaking very few miles later ( i just did this last winter). I suspect the grooves ate up the new gaskets. Considering this, and what everyone else says about to durability the repair, and you don't have the option of doing the bellows easily/cheaply, you'll get longer life out of it esp if yours are grooved up.
Old Dec 1, 2009 | 12:16 PM
superduty4x4
New pipes aren't in the budget right now, I'll have to cross my fingers and hope mine aren't hosed.
Old Dec 1, 2009 | 01:16 PM
jkidd_39's Avatar
jkidd_39
Are you sure they aren't too expensive Chase?
I know Brad (Beanhead) fixed his uppipes for less than a hundred bux if memory serves right
Old Dec 1, 2009 | 02:48 PM
aldridgec's Avatar
aldridgec
Honestly, my opinion is hold off if it isn't that bad. If it was so bad you couldn't build any boost then it would be worth patching up. Mine aren't that bad again (yet), but I can hear it and smell a little when the EBPV is closed in the AM. I won't replace the gaskets again without either new pipes or bellowed pipes, not worth the trouble.
Old Dec 1, 2009 | 02:56 PM
superduty4x4
I don't know for sure, but I think new pipes are $200-300.
Old Dec 1, 2009 | 03:19 PM
PwerStroke99
STFU soldier boy!
Only speaking the truth!!!
