Chasing a Vibration in my Excursion
I know this is the wrong forum, but I posted this in the Excursion forum with no reply. Since the Ex has the same chassis as the Super Duty, I figured that I would re-post over in this forum.
https://www.ford-trucks.com/forums/9...in-the-ex.html
Well, I bought this Ex a little over a month ago and finally got around to replacing some stuff.
I have a slight vibration between 50 and 60 MPH. The vibration is the same weather I am accelerating, in Neutral, Coasting down (well, a little bit worse when coasting down), in 2WD, in 4WD, turning, going straight, hot or cold.
I have replaced the following:
Rear Driveshaft U-Joints
Tires and Rims
Upper and Lower Ball Joints
Wheel Bearings
Steering Stabilizer
Cleaned and Greased the Hubs
Greased everything greasable up front
I still have the exact same vibration as when I started. I can feel the vibration in the steering wheel as well as in the body of the vehicle. I am thinking that it may be in the steering linkage. If there is a loose joint then the wheels would be allowed to jiggle a little bit. I am at a loss. What else should I check?
Also, When doing the ball joints, I noticed that the tie rod ends were quite stiff. How stiff should these be? I can't move them by hand, but they will move a little bit when moving the free end of the tie rod.
Any help will be much appreciated. I am taking it in for an alignment on Friday, and if I can't figure this vibration out, I might have them take a quick look into it.
Would a stuck slide pin in the front brakes do this? Both sides on my truck are siezed at the current moment.
Thanks in advance,
Greg <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
Tires and Rims
Wheel Bearings
Steering Stabilizer
Thanks in advance,
Yeah, I thought the same thing with the brakes. I do need to fix that issue anyways.
I have the Manual/Auto stock Ford Hubs with ESOF. Yes, they are unlocked. I have checked it by hand before driving. I have also tried shifting into 4WD while moving at 55 mph to see if it made any difference at all...Nope. I have also locked them in by hand then taken a test drive. No luck.
Crazy001-
Thank you for the reply. You have just confirmed my suspicions. I will just have to bite the bullet and let someone else troubleshoot my truck. I hate when I can't pinpoint an issue, but I hate throwing parts at a problem with no results even more. Money is tight right now, so it would probably just be better for a pro to do it.
Thanks again.
Thanks again.
Anxious to see results, my truck has lots of odd vibration, but with my front end having all those issues I havent even thought about looking somewhere else on the truck. Perhaps its a rear axle bearing? Sounds like the one place you havent looked.
Also, could be a broken belt in the tire. Just because they are new doesnt mean theyre good
I have pretty much ruled the driveshafts out. I removed the rear driveshaft and took it for a quick spin in 4WD (using the front Axle to pull the truck). Same vibration.
I don't have spindles since it is a 4WD. The front wheel bearings are unit bearings that bolt onto the knuckle. I have checked that I have power steering fluid, but I haven't changed it yet.
Well, I think I have found the issue. While I was under the truck checking the Engine and Tranny mounts (Which are still good by the way) I had my girlfriend move the steering wheel back and forth. It looks like I have a bad tie rod end. The end that is on the Tie Rod connecting the drag link to the tie rod. When it moves back and forth there is some left to right and up and down movement (about 3/16"). I will order these parts put them on and have an alignment done. Hopefully I will have some final results by next week.
Thanks for all the replies and the help.
Greg
Greg
