Connecticut Chapter Join Chapter, Leader:
December B/S Thread
Old Dec 18, 2009 | 04:33 PM
  #376
Nice Work Truck's Avatar
Nice Work Truck
Greg when I ordered mine they would not do a plow prep package on mine ether.
I gust wanted it for the heaver springs.
Old Dec 18, 2009 | 04:35 PM
  #377
Aerocell4x4's Avatar
Aerocell4x4
Diesel Van Enthusiast
Hi Andy
Work is good, TY how goes remodeling for you?
I figured its likely slow as no-one wants their house under reconstruction across the holidays.
  #378
7.3 Rocket's Avatar
7.3 Rocket
Originally Posted by gbroehl1
As ready as I can be. Plow is still in the garage but it only takes a minute or two to roll it out on the dollys. I need the extra weight to offset the plow (behind the rear axle). According to Ford I should not even have a plow on a crew cab diesel.
Cause they figure you will have every seat filled and that would put you over your GVWR. With just you in the truck you're fine. They also don't think an F350 should sling around a 9' Fisher MC but I know of an OBS 7.3 that will be doing that.
Too bad it's in hartford until Wednesday at the earliest. And it's got no body and we need to put in a dually rear and register it and insure it. So basically no way in hell it will be ready for this year.
Old Dec 18, 2009 | 04:36 PM
  #379
Nice Work Truck
Dave my daily weight is 12,000 lbs.
I don't think i need any more.
Old Dec 18, 2009 | 04:40 PM
  #380
Nice Work Truck
Originally Posted by Aerocell4x4
Hi Andy
I am working on a kitchen right now when the people are in FL for the winter so I can work any day I want witch is good so I can get caught up. I am about 3 weeks behind right now.
I just waiting for the wife with the PIZZA.
Old Dec 18, 2009 | 04:48 PM
  #381
Aerocell4x4
As for our Dana 60 front axles they can only carry about 4500 pounds and Dana includes in that weight the weight of the Dana axle (~500#) and the weight of the tires & rims (et. al.) bolted to the axle.
When Quigley delivered my van, they told me I had ~400 pounds available up front before the axle was loaded to capacity.
Quigley, puts in 1-up coil springs if the van didn't have that option when ordered from the factory.
I don't know what 1-up represent?
I'm guessing either one extra turn in the coil for extra height?
Maybe a load carrying class increase by 1 level?
So with the tonnage of a diesel engine, there isn't much rated margin left to hang a snowplow and rumble down the highway.
Old Dec 18, 2009 | 04:52 PM
  #382
gbroehl1's Avatar
gbroehl1
Yeah, I had to install the plow springs on mine in the middle of last winter due to the plow dragging to much.
Old Dec 18, 2009 | 04:53 PM
  #383
gbroehl1's Avatar
gbroehl1
Yeah, I understand their reasoning (if you can call it that), I just don't like to listen
Old Dec 18, 2009 | 04:55 PM
  #384
Aerocell4x4
Good evening Pete
You should check out my van with the Rickson 19.5" conversion rims before you go and put a dually axle on that truck.
My singles as a set can carry 10,000 pounds, the rim is the weak link, only good for 5000 pounds. the tires as a set can carry up to 12790 at 120 psig.
Old Dec 18, 2009 | 05:08 PM
  #385
BIGKEN's Avatar
BIGKEN
Howdy CT...Welcome to the Weekend!!!
Old Dec 18, 2009 | 05:09 PM
  #386
7.3 Rocket's Avatar
7.3 Rocket
Good evening Pete
Dave we already own the axle and a dually flatbed body. It's more of a stability when towing issue than a capacity issue.
Old Dec 18, 2009 | 05:10 PM
  #387
BIGKEN's Avatar
BIGKEN
Evening everyone. I just finished loading 1200# of winter weight into my truck, ugh
What's her name???
Old Dec 18, 2009 | 05:34 PM
  #388
tbenks's Avatar
tbenks
hmm all this talk of d60's, how big of project would it be to swap my tbb for a 60?
Old Dec 18, 2009 | 05:42 PM
  #389
Aerocell4x4
Hi Ken
Old Dec 18, 2009 | 05:44 PM
  #390
Aerocell4x4
Hi Tim
I don't have a clue.
But if you are going to swap out a front axle then consider
Dana 60 - Wikipedia
Dana 70 - Wikipedia
