Maryland Chapter Join Chapter, Leader:
December chat thread
Old Dec 6, 2009 | 07:51 PM
  #871
jr32560's Avatar
jr32560
wish I had a picture for ya Pat
Old Dec 6, 2009 | 07:52 PM
  #872
1OldFordMan's Avatar
1OldFordMan
Originally Posted by jr32560
HEY CHARLIE!!! help me out here a bit maybe I explained it wrong ?
I didn't get to see what was in there, he pried it out & put the new one in while I stood outside the door & watched him sitting in the driver's seat. My Zone manual doesn't show what's there unless it's in a different section.
Old Dec 6, 2009 | 07:55 PM
  #873
1OldFordMan
Pitchers is always good fer me. Not quite Sofa King yet , but could be close. Good thing Misery is The Show Me State.
Old Dec 6, 2009 | 07:57 PM
  #874
jr32560's Avatar
jr32560
have ya looked in the tech tips in the 87-96 forums yet maybe they have a diagram?
Old Dec 6, 2009 | 08:02 PM
  #875
1OldFordMan
Good idea!!
Old Dec 6, 2009 | 08:03 PM
  #876
dustybumpers's Avatar
dustybumpers
and I'm good with my one charlie
don't want that one, that would be like keeping 2 of mine, only would cost more money
Originally Posted by 1OldFordMan
Actuator?? Know what the rod is & have a new electrical switch to put on, but what is the actuator? Thought the key cylinder pushed the end of the rod & that pushed the switch?
end of the key cyl turns a brass gear, which pushes the rod, which engages the switch. if key is working, and rod is moveing, switch is probably loose.rod is just shoveing it up and down on the column, and not engageing. when you are yanking on the rod, you are distorting it to make the switch work. evenyually you will bend the crap out of the rod, so that it will NEVER AGAIN WORK.............. how's that JR?
  #877
ford to the bone's Avatar
ford to the bone
ford to the bone
you are you guys trying to take apart
Old Dec 6, 2009 | 08:05 PM
  #878
1OldFordMan
Not yanking, just wiggling side to side. That's what I meant when I said it felt sloppy. Is it supposed to have that much play? Is that brass gear you're talking about what Jr. called an actuator?
Old Dec 6, 2009 | 08:06 PM
  #879
jr32560's Avatar
jr32560
well like you said charlie on the end of the key switch or cylinder is a cog -and it intertwines with a flat actuator with grooves on it -that attaches to the rod then down to the actual electric part on the top of the column the switch -it's complicated to explain
Old Dec 6, 2009 | 08:07 PM
  #880
jr32560's Avatar
jr32560
it's not working correctly John
Old Dec 6, 2009 | 08:09 PM
  #881
dustybumpers
ok. let's try this again. THE SWITCH IS LOOSE PAT. TIGHTEN THE DAMN SCREWS BEFORE IT FALLS OFF.
Old Dec 6, 2009 | 08:12 PM
  #882
1OldFordMan
Will try that in the A.M. when it gets daylight again.
Old Dec 6, 2009 | 08:26 PM
  #883
jr32560's Avatar
jr32560
It should be on the top of the column about half way down from the top -slightly to the left side just feel just below the dash on top ~you should feel the rod cover or the rod itself just follow it down to the switch -it has 2 screws in it If i remember right
now my CRS is kicking in
what was I talkin about ?
Old Dec 6, 2009 | 08:30 PM
  #884
ford to the bone
ford to the bone
jr found out what happin to the old truck
Old Dec 6, 2009 | 08:32 PM
  #885
1OldFordMan
Thanks Jr. Wasn't sure exactly where it was. Not fond of standing on my head to look under the dash, too old for that. Back in my younger days......
