Dp-tuner??
Old Dec 1, 2009 | 01:55 AM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Dp-tuner??
I bought a boost ann. and a cold air intake. I am planning on getting the Snow stage II and a wicked wheel if I don't have one already. My question is do I need to get my DP reburned or can I put these on my ride without harming anything? Also my truck somkes alot in all tunes. Normal??
Old Dec 1, 2009 | 04:10 AM
Visseroth's Avatar
Visseroth
I would say that the answer to your first question is no, you don't need a re-burn.
The WW is just going to make the turbo work better.
As to why you're smoking.... Do you have a boost gauge? How much boost are you getting? You shouldn't be smoking except when stomping on it.
What is your MPG?
Old Dec 1, 2009 | 05:38 AM
spdmpo's Avatar
spdmpo
What's that trans com in your sig? Might not be a good idea to have something like that with the DP tuner.
Old Dec 1, 2009 | 05:18 PM
zx250's Avatar
zx250
Of the next Riffraff East
What color smoke are you getting? Lots of black smoke could be as simple a dirty air filter or boost leak.
Old Dec 1, 2009 | 05:25 PM
rbaker6336's Avatar
rbaker6336
Would think the tunes you have would produce a good bit of smoke.In 80E mine smokes a good bit (actually more than I like) with a frisky take off
Old Dec 1, 2009 | 05:34 PM
zx250's Avatar
zx250
I guess it depends on his definition of "smokes a lot". Mine will smoke, but only if I get on it or have it on one of the higher tunes. Excessive smoke usually points to a problem somewhere.
Old Dec 2, 2009 | 12:16 AM
diesel-fitter-bum01
So I won't need a re-burn with these additions? Kinda what Ray is talking about, every tune more than wanted, but I will live with it I like it Just wondering if anyone else was smoking that much. Jody knew about the trans. com. when I ordered the chip and he didn't say anything about me needing to remove it.
Old Dec 2, 2009 | 12:18 AM
diesel-fitter-bum01
Running 24lbs of boost max now. Getting 15 to 19 mpg. Smoke is always black.
Old Dec 2, 2009 | 06:47 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
I just checked with Jody and he says if you like harder firm shifting keep it, if you don't like it after the chip is installed unhook the trans. com.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Dec 3, 2009 | 03:02 AM
diesel-fitter-bum01
My girl shifts like a dream, except when slowing down. At the 45mph range it downshifts hard and I usually am ready with the brakes to help it slow down. I was told though with any additions I would have to update the chip. Just wondering if tat's true?
Old Dec 3, 2009 | 07:17 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Not with all new additons.
Some, yes...
Changing injectors- going from Splits to Singles.
Installing dual HPOP's
Some aftermarket valve bodies or fully built tranny's require new tunes.
Bigger turbo's- depends on how efficent the trubo is.
Using NOS, meth mixed with water or Propane.
__________________
Old Dec 3, 2009 | 09:43 PM
diesel-fitter-bum01
Great! thanks so much
