Here it is!
Old Dec 1, 2009 | 03:33 PM
dyoung14's Avatar
dyoung14
o im sure it will shorten the life span, as far as the weird rattle going up the mountain, im going to get rid of my factory 6.9 rockers to start with
Old Dec 1, 2009 | 04:21 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I'd like to see Dave Sponaugle's opinion on this.
Old Dec 1, 2009 | 05:19 PM
dyoung14's Avatar
dyoung14
hi opionion is its gonna blow, i can tell you that
Old Dec 1, 2009 | 11:20 PM
Dave Sponaugle's Avatar
Dave Sponaugle
That rattle was the lifters/valves floating.
I am half deaf, but I still heard them rattle in the video.
Before I thought about running close to that kind of RPM I would want to install 7.3 turbo valves, probably new valve springs that were slightly stronger than stock and most definitely 7.3 rockers.
If a rocker breaks, which RPM that high is likely to do, then it may turn and knock the keepers out on a valve.
So the the valve drops in to the cylinder and as soon as the piston comes up, you can kiss that block and head goodbye.
Having the rotating assembly balanced would also be a good idea.
Also may want to consider some stronger fasteners for the rod caps.
Sure would be a shame to see a fine engine block turned to scrap because something let go.
Wonder how I know that?
