Front drive shaft problem
Old Nov 30, 2009 | 09:06 PM
jpjohnsr's Avatar
jpjohnsr
I have a problem with my 1997 explorer xlt AWD. The rear of the drive shaft does not have a U-joint. It is rattling to be damned. When i inspected close up the rear of the shaft will shake like it is loose. I have priced a new shaft and it is way beyond my budget right now. Can i remove the front drive shaft and run with out it till i can scrape up the money for a new one or find one in a salvage yard? Any help on this would be awsome.
Old Dec 1, 2009 | 05:48 PM
boots6868's Avatar
boots6868
I dont see why you couldnt drive it without the foward drive shaft in place. even if the transfer case kicks in if you got auto 4x4 it will just free spin. I mean it sure wont leak there or anything, you just wont have front axle hook up. try it out.
Yeah i just removed one on a 98 and it sure looks like you would have to replace the whole shaft unit should it wear out there.
Old Dec 2, 2009 | 02:55 AM
WyoExplorer's Avatar
WyoExplorer
I'm driving with no front shaft, it doesn't handle any different, just a bit quciker in acceleration, less restriction I guess.
Other than that (it's been like this for 6 months) there are ZERO issues
Old Dec 2, 2009 | 09:11 PM
jpjohnsr's Avatar
jpjohnsr
is there anything special i need to do or can i just remove the front shaft?
Old Dec 2, 2009 | 11:34 PM
boots6868's Avatar
boots6868
just take out the front shaft. make sure your using a good #30 torx bit to remove the universal cap straps, i broke a good blue point torx luckily it came right out with a magnet. then i used a snap on to remove them lucky there are only 4 of them. on the back end you got a series of bolts with straps too then she comes right out.
Old Dec 2, 2009 | 11:52 PM
WyoExplorer
Thank you Boots, I forgot to mention that, if you cannot Get a good torx bit, find a parts store near you that honors their tools with lifetime replacement warranty, make sure they have a few or more, you WILL break a few, I went through about 3 of em.
Old Dec 5, 2009 | 05:27 PM
jpjohnsr's Avatar
jpjohnsr
Well guys I took out the shaft today. I can not say it was the easiest thing I have ever done, but it was by no means the hardest either. The test drive (about 40 miles) went well. Thanks for your help and advice guys. After your advice about the torx head bolts, I bought a can of PB Blaster Penetrating Catalyst and sprayed down all the bolts ten Mins. before I even atempted to take the out. I am here to tell you it lived up to its billing. That stuff beat liquid wrench hands down. Took one little tap on the retchet end for each bolt and out the came. Thank God for better living through modern chemistry.
passthegaff
Mar 13, 2017 08:21 PM
jplinville
Oct 17, 2016 08:41 PM
AlphaFox
1978 - 1996 Big Bronco
Aug 22, 2016 10:13 AM
7283-F250
1983 - 2012 Ranger & B-Series
Jun 5, 2016 02:19 PM
pcpotter1023
Jul 7, 2015 10:21 PM
