Another Altenator Question
Old Nov 9, 2017 | 04:24 PM
vfelix702's Avatar
vfelix702
Try bench testing new alternator
Old Nov 9, 2017 | 04:27 PM
ct1927's Avatar
ct1927
Alternator voltage output...14.4 - 14.1 Volts. Alternator testing good.
Old Nov 9, 2017 | 06:21 PM
TooManyToys.'s Avatar
TooManyToys.
The alternator is reading 14.4v at the exact same time your dash is showing below 12v?
Alternator testing where/how?
Old Nov 10, 2017 | 06:11 AM
ct1927's Avatar
ct1927
At idle the alternator puts out 14.1 - 14.4 volts. When driving and (gradually) accelerating, per voltage reading from cigarette lighter (inside cab), voltage output drops below 12 volts. Voltage drops below 12V when accelerate, causing low voltage indicator light to flicker on dash.
Old Nov 11, 2017 | 03:50 PM
wedge542's Avatar
wedge542
Recheck that new belt routing and make sure belts tight, have you heard engine fan at all since new belt and alt put on?
sunuvabug
Jun 22, 2024 01:58 PM
gearloose1
Jan 1, 2020 05:03 PM
scottsmith
Sep 4, 2018 08:29 AM
andyb6381
Feb 7, 2018 12:00 PM
flysniper
Jan 31, 2018 05:54 PM
