Engine cleaning...
Old Nov 30, 2009 | 10:59 AM
JGreen236's Avatar
JGreen236
Engine cleaning...
Alright me and a friend tore down an engine last Saturday. We took both heads out, the rockers etc. Everything is covered with what looks like milkshake, on top of that theres about two inches of engine sludge throughout. My question is what is the safest way to clean out an engine? Would an engine degreaser be out of the question for spraying out the inside of it?
Old Nov 30, 2009 | 01:15 PM
bashby's Avatar
bashby
An old shop vac works good to keep chunks out of the oil pan, it would be best to drop the pan then you can flush everything out without cloggging the pickup screen
Old Nov 30, 2009 | 01:48 PM
JGreen236's Avatar
JGreen236
Can the heads be cleaned out with carb cleaner? The springs and rockers are disgusting.
Old Nov 30, 2009 | 02:13 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
It can yes, but be aware that the carb cleaner will clean all the oil off the parts.
It would be better to dismantle the engine, and reassymble it after cleaning using an assymbly lube etc...
If the milkshake substance is just water mixed with the oil. Using fresh oil, and engine heat will clean and extract the water with time, and is better than using solvents in my opinion, especially if you are not going for a rebuild. Change the oil and filter between 100/500 miles untill the moisture is gone should do it.
Old Nov 30, 2009 | 06:06 PM
bashby's Avatar
bashby
Carb cleaner is fine, Brakecleaner is a little easier on the nose,get a parts cleaning brush and go for it.
Old Nov 30, 2009 | 07:44 PM
dustybumpers's Avatar
dustybumpers
I use gas, then clean it the 2nd time with brake clean. don't smoke while doing this, and you will want to be outside. stiff wire brushes, some round, some square are a big help. put down plenty of card board, to help contain the mess.
Old Dec 1, 2009 | 11:36 AM
JGreen236's Avatar
JGreen236
After cleaning most of it out that should improve the performance of the engine correct?
Old Dec 1, 2009 | 01:17 PM
Franklin2's Avatar
Franklin2
Cleaning the gunk out will not turn your motor back into a well cared for unit that will last many miles. I hate to tell you, but if it was that sludged up, the oil had not been changed very often and or it was driven on many short trips and the thermostat may have failed open also. All of this creates wear in the engine, so cross your fingers and hope for the best, that's where you are at right now. Hopefully none of the sludge will or has made it into the oil pan where it can clog the pickup screen on the oil pump.
Old Dec 1, 2009 | 01:56 PM
JGreen236's Avatar
JGreen236
I see I see! Thanks guys, really crazy how much you can learn about an engine just by taking it apart and asking a few questions =P
Old Dec 1, 2009 | 04:34 PM
dustybumpers
you should at least put in bearings, and a new oil pump if you have it down that far.
Old Dec 1, 2009 | 10:14 PM
81-F-150-Explorer
I agree. Wholeheartedly.
Old Dec 2, 2009 | 03:25 PM
JGreen236's Avatar
JGreen236
I'm full of questions this week =P
Whats the best way to clean out the fuel lines?
Old Dec 2, 2009 | 05:45 PM
dustybumpers
no problem. keep asking, that's how we learn. open both ends, squirt some brake clean in there, then blow it out with an air hose
Old Dec 3, 2009 | 09:26 AM
JGreen236's Avatar
JGreen236
Alright thanks! My gas tank had rust in it so I've gone ahead replaced it, bought a new sending unit, so thats all brand new... should I just buy a new fuel pump? Its the pump that is on the engine.
Old Dec 3, 2009 | 09:39 AM
bashby's Avatar
bashby
If the pumps working and not leaking I wouldnt replace it. I dont see any reason to clean the fuel lines either
