Turbo???
Old Nov 30, 2009 | 08:41 AM
skysoldier69's Avatar
skysoldier69
Turbo???
'04 6.0l PSD Turbo Back 4" exhaust( no Cat), K&N Filter, and 43K miles. While pulling 12K lb. 5th wheel got turbo fart while numerous times while cruising at 65 -70 mph. Get puffs of black smoke each time is farts. I get on it and it goes away. Also slow down to 60 mph and ease it up to 65 mph (trans downshifts) it will do okay for awhile. Codes show Turbo Underboost, EGR sensor A and EGR Circuit. Cleaned EGR Valve. Had powdery soot on valve, not wet. Took it out and drove up to 95 mph several times, no problems. Pulled fiver again. Did okay first 90 miles or so (outdoor temp. 52 degrees.). On return trip outdoor temp. 71 degrees and did turbo fart c**p again. What are your thoughts on this?
Old Nov 30, 2009 | 05:43 PM
dcaddi2's Avatar
dcaddi2
Sticking turbo vanes?
Old Nov 30, 2009 | 06:21 PM
3000 FPS's Avatar
3000 FPS
Sounds like sticking turbo vanes to me. Do you have a boost gauge on your truck? It is very common for these trucks to overboost when pulling a heavy load when the turbo is sticking. That is when damage to other parts of the engine can occur.
Old Dec 1, 2009 | 10:52 AM
skysoldier69
thanks, guys. I figured as much. Guess I'll have to pull and clean.
utjer
May 19, 2013 08:39 AM
danocross
Jul 20, 2012 09:06 AM
f350fixaliter
Oct 3, 2010 08:30 PM
tony2fingers
Jun 30, 2009 07:14 AM
