Sponsored by: Real Truck
oil leak
Old Nov 29, 2009 | 01:41 PM
imthatguy's Avatar
imthatguy
oil leak
i have an oil leak on the top of my 2002 f-250 7.3 filling up the wells and flowing over at first this was a very minor leak but now has degraded into a problem any idea of where it could be coming from? I noted oil on and around the sensor on the front lhd side i have a hard time believing that this is the root cause. Any suggestions?
Old Nov 29, 2009 | 01:48 PM
Cuda_jim's Avatar
Cuda_jim
There are many places the leak can be coming from.
You need to get as much stuff out of the way as possible and clean the engine valley. Use a screwdriver and paper towels to soak it up. You can also lift the front of the vehicle as high as possible and flood the valley with a degreaser and water, most of it will run out of the back of the valley onto the ground. Dry up the remaining water. Get a good light, fire it up and look for the source.
It could be diesel too unless you're absolutely sure it's just oil.
Old Dec 9, 2009 | 04:30 PM
imthatguy's Avatar
imthatguy
oil leak
i have a leak underneath the filter housing on my high pressure oil lines how do these hoses come off i do not see any clips only a black rubber ring with diamonds on it. please help
Old Dec 10, 2009 | 05:39 PM
Cuda_jim's Avatar
Cuda_jim
You need a special tool to remove the lines (below). You could make one.
Old Dec 13, 2009 | 09:26 PM
imthatguy's Avatar
imthatguy
thanks I was able to grid down an old 9/16 wrench it was tough to get down to it so I heated it up an bent it a couple of times was able to get it right off thanks for all of your help
snaponprofile
16
Nov 4, 2011 08:47 AM
Hunter8354
Feb 12, 2009 10:51 PM
ryansmo
Feb 26, 2008 10:55 PM
sltintexas
Jul 29, 2005 04:01 PM
redygo
Feb 12, 2004 08:39 PM
