Sponsored by: Real Truck
2008 7 pin color code
Old Nov 29, 2009 | 12:12 PM
Jammin1's Avatar
Jammin1
I am wiring up some under the bed lights for plowing. I would like to know what the colors of the wires are for the rev. lights and the 12v in the trailering harness. I need to tap into those wires
Old Nov 30, 2009 | 12:14 PM
pbeering's Avatar
pbeering
There should be a legend on the cap of the light socket. You might consider buying a trailer light plug and wiring to it.
Use heat shrink butt connectors or heat shrink tube in either case.
Back up lights are the center pin.
marker lights are the 11 o'clock pin.
If you are installing a high draw light, install a relay.
AndeyHall
Feb 20, 2018 08:03 PM
V10Crew
Oct 28, 2010 03:13 PM
PSDx3
Mar 27, 2010 08:50 PM
