huge timing problem
Old Nov 28, 2009 | 09:28 PM
93f15042's Avatar
93f15042
huge timing problem
<TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top width="100%" itxtvisited="1">i am haveing a huge problem just built my 351w it is bored 40 over stock cam everything is stock when i went to time it i put it to 10 btdc it idles at 2000rpm new iac sensor new tps new map sensor. when i put into driver when it is cold it runs fine for a few then when it warms up it wants to die and stall i have to feather the gas any ideas need help </TD></TR></TBODY></TABLE>
Old Nov 28, 2009 | 09:31 PM
Conanski's Avatar
Conanski
Any codes? If not you may have a intake gasket leak.
Old Nov 28, 2009 | 09:58 PM
93f15042's Avatar
93f15042
now could it be a lower intake leak or just the upper intake
Old Nov 29, 2009 | 10:52 AM
WhiteZombie's Avatar
WhiteZombie
leave it in neutral and hit the gas a few times if it pops or back fires the distirbutor is 180 degrees off. i had a similar problem when building my 351
Hillbilly11
Texas Chapter
Jan 31, 2010 01:54 PM
LARIAT 85
Jan 14, 2009 05:49 AM
donny3369
Dec 3, 2008 08:13 PM
Bigfwt04
Nov 6, 2008 08:54 AM
