huge timing problem
Old Nov 28, 2009 | 08:16 PM
93f15042's Avatar
93f15042
huge timing problem
i am haveing a huge problem just built my 351w it is bored 40 over stock cam everything is stock when i went to time it i put it to 10 btdc it idles at 2000rpm new iac sensor new tps new map sensor. when i put into driver when it is cold it runs fine for a few then when it warms up it wants to die and stall i have to feather the gas any ideas need help
Old Nov 28, 2009 | 08:32 PM
maskedman's Avatar
maskedman
You need to post this question in the small block forum.
Old Dec 1, 2009 | 07:16 AM
grclark351's Avatar
grclark351
vacuum leak?
