Ford installed anti theft
Old Nov 28, 2009 | 01:17 PM
geraldo14's Avatar
geraldo14
I have posted a similar question about this issue months ago but I think that maybe the Ford Dealership installed anti-theft device under the drivers side dash may have something to do with my problem. The connection piece under the dash looks like it used to use a card that would slip into the slot to make the truck available to start. I called the dealership and the service man told me that they could activate it again but at a high cost. What happened is I locked my keys in my truck and AAA tried to open my truck but no luck. After that, my keyless remote does not open or lock my doors. I have a brand new remote and a spare with a new battery and even after going through the progamming process, it still doesn't work. Maybe that dealership anti theft device is blocking the remote access and programming? I'm lost and I'm frustrated. Any ideas or opinions would be greatly appreciated.
JR
Old Nov 28, 2009 | 07:40 PM
Franklin2's Avatar
Franklin2
I don't know much about alarms. If you end up going to the dealer, I would pay the "high cost" to have to removed.
Old Nov 28, 2009 | 09:46 PM
mndiesel's Avatar
mndiesel
Maybe try disconnecting your batteries for a few minutes to give the system a reset and then try reprogramming. It might work, you never know.
Old Nov 29, 2009 | 11:27 AM
geraldo14's Avatar
geraldo14
Thanks
Thanks you guys for your ideas, at this point I'll try anything.
Old Nov 29, 2009 | 11:28 PM
IDMooseMan's Avatar
IDMooseMan
What happened? Did it work?
Old Nov 30, 2009 | 11:02 AM
geraldo14's Avatar
geraldo14
time
I haven't tried disconnecting the battery yet, I will today and I'll let you know what I find out.
Old Nov 30, 2009 | 04:23 PM
geraldo14's Avatar
geraldo14
nothing works
I disconnected the battery in the truck along with pulling the batteries out of the remotes. I ran it through the programming process and it they still don't work. The odd part is following the manual's steps, when you're done programming the doors are supposed to remain in the locked position but what happens is, the door locks cycle and then end up in the unlocked position.
freeranger
2015 - 2020 F150
19
Mar 13, 2022 05:28 PM
Hotrodkid94
Aug 12, 2016 03:03 AM
F1Hunter
41
Jan 2, 2016 03:38 PM
kslhol
15
Feb 1, 2007 03:42 PM
pharbach
1997 - 2003 F150
Nov 23, 2004 04:08 PM
