won't start
Old Nov 28, 2009 | 09:49 AM
bkbkbkbk's Avatar
bkbkbkbk
won't start
Ive got a '96 7.3L F350 with 220k on it. When I turn the key relay #4 under the hood clicks and the wait to start light blinks in sync with the click of the relay. Any help?
Thanks
Old Nov 28, 2009 | 12:32 PM
bkbkbkbk's Avatar
bkbkbkbk
bump. anyone have any idea?
Old Nov 28, 2009 | 12:49 PM
CampSpringsJohn's Avatar
CampSpringsJohn
What about the selenoid on the engine? Does it make any noise. If a relay is clicking and the WTS light is flashing, something is shorted out. There are 2 selenoids on top of the engine, on the passenger side by the valve cover. I can't remember which one is for the glow plugs and which one goes to the starter. Figure out which one goes to the GP's, and cross the terminals with a screwdriver. Sparks will fly, and the screwdriver will get hot. Hold that for about 30 seconds and see if that warms the engine up enough to start. BTW, when you were trying to start it before, was there any white smoke coming from the tailpipe?
Old Nov 28, 2009 | 12:52 PM
CampSpringsJohn
How rude of me, Welcome to FTE! There aren't many people on here today so that would explain the lack of responses. Holiday weekend so many of the regulars are busy doing stuff with their families or shopping.
Old Nov 28, 2009 | 12:57 PM
CampSpringsJohn
Was also reminded about this in another thread, try unplugging your fuel filter heater.
Old Nov 28, 2009 | 09:04 PM
MissIndependent's Avatar
MissIndependent
starter solenoid i believe is just left of the coolant reservoir...i got to do the screwdriver thing myself yesterday
Old Nov 28, 2009 | 09:43 PM
CampSpringsJohn
You are correct MissIndependent. These newer style selenoids are easy to jump across. The old ones like on the 70's and such you needed a wire. The main terminals are on the sides so you can't arc across them with a screwdriver.
Old Nov 29, 2009 | 09:46 AM
bkbkbkbk's Avatar
bkbkbkbk
If you cross out the GP relay the engine will start and cut on and off in sync with the flashing WTS light
Old Nov 29, 2009 | 09:54 AM
CampSpringsJohn
Try unplugging the heater on the fuel filter housing.
https://www.ford-trucks.com/forums/9...ure-cause.html
Look at the 6th post in this thread for finding the heater in the fuel filter housing.
Old Nov 29, 2009 | 12:11 PM
Action4478's Avatar
Action4478
I might make sure the charging system is working properly & the batteries are fully charged, look at all the fuses carefully ...
In the distribution box under the hood , there are 4 small relays , try switching the positions of them
mikels
17
Jul 21, 2021 12:08 AM
hrspowr
Jan 25, 2021 02:14 PM
Codeman894
Sep 28, 2017 08:59 AM
liquidlounge
Dec 3, 2014 04:39 AM
thelemur
Mar 15, 2004 01:03 PM
