Need some help
Old Nov 28, 2009 | 12:32 AM
96F150EddieBauer's Avatar
96F150EddieBauer
Need some help
I've been here a few times seeking help, and have always gotten very good information. I tried logging into my account i used about a year or so ago and no such luck, image verification would not work.
Any rate, i have a 1996 F-150, 4.9L, 5 speed, eddie bauer package. I was driving to work last week when my entire exhaust fell off, ripping the bottom of my 02 sensor off, leaving the wires exposed. I thought it had simply ripped it out of the other end of the sensor. Was suppose to be worked on the following weekend. My exhaust guy flaked out of me.
So about midway through last week i was driving and my battery gauge started going crazy and my battery light came on and the truck stalled out. I pulled over to the side of the road and got out and checked my battery connection, everything was tight. So i tried starting the truck, it will crank over but not fire. I sprayed some ether in the intake and it fired. So my problem now is i am not getting any fuel, Will crank but i dont hear the fuel pumps even coming on.
I checked all my fuses and relays under the hood, they all are fine. Also checked the inertia switch, just in case. It was fine. So as uncommon as a problem as this is, im just looking for ideas in what i can check, going to check tommrow to see if my fuel pump is getting any power. Then go from there. So if anyone has any ideas of what i can check, it is very much appreciated.
Old Nov 28, 2009 | 01:58 AM
jplinville's Avatar
jplinville
Dumb question, but could the tank or line have a hole in them leaking out? Just a thought...
Old Nov 28, 2009 | 06:32 AM
subford's Avatar
subford
Sounds like your Red #361 wire is dead.
I would recheck Fuse #9 it is a 20 amp fuse in your engine compartment fuse box.
If not that check to see if the PCM Power Relay is making (clicks) when you turn on the key.
You can check the red wire to see if it is hot with the key on at any fuel injector.
Old Nov 28, 2009 | 07:38 AM
96F150EddieBauer
Thanks for the replies. I think i am going to stop at the parts store on my way today. And pick up two relays and two 20 amp fuses. Just replace them to make sure they are good. I will also check my Red #361 wire, thank you.
Old Nov 28, 2009 | 08:07 AM
subford's Avatar
subford
Note Fuse #9 might be 30 amps.The location of fuse #9:
PCM POWER RELAY:
FUEL PUMP RELAY:
