AIH delete
Old Nov 27, 2009 | 11:29 PM
61 uni's Avatar
61 uni
AIH delete
What do you do with the wires and relay when deleting the AIH?
Old Nov 27, 2009 | 11:33 PM
Kwikkordead's Avatar
Kwikkordead
I left the relay in place as a spare glow plug relay.
Four years ago, I needed it and swapped the wires over.
Still that way today.
Old Nov 27, 2009 | 11:57 PM
tdpower's Avatar
tdpower
http://www.dieselsite.com/index.asp?...PROD&ProdID=48
Old Nov 28, 2009 | 06:43 AM
throwdown's Avatar
throwdown
If you want to eliminate the code, after removing and plugging the AIH, make a pigtail or crossover with a 470ohm, 1w resistor and attach it between the two wires, (power and ground), that you just took off of the AIH. This will fool the system and eliminate the code.
I have done this mod and I got the info from doing a search for " AIH delete " in the forum search from the drop down menu above.
I used a heat shrink on the whole thing after installation.
And as Kwik says, you will always have a spare relay under the hood when needed. Good luck.
Old Nov 28, 2009 | 05:55 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Just take em out Brandon. Theres two less wires clogging up the valley. As mentioned it will only leave a soft code.
