Modular V10 (6.8l)
Engine trouble code and diagonosis help
Old Nov 27, 2009 | 04:37 PM
Pinzer's Avatar
Pinzer
'02, F350, V10. I had a P0171 and P0301 codes as read by Auto Zone. I had planned on changing the plugs anyway since I didn't know the history of the truck.
So I changed the plugs and boots - what a PIA job that is! Anyway, how do I reset the check engine light, just disconnect the battery?
Thanks.
Old Nov 30, 2009 | 12:01 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yup, just disconnect the battery for an hour or so.
The "bank 1 too lean code", P0171, can mean a vacuum leak. That pesky rubber elbow for the PCV plumbing as it hits the throttle body can do that to you.
The P0301 is a cylinder #1 misfire, is in "bank 1", and again, that vacuum leak can cause that too.
I don't think the plugs are what is causing this, and a few drive cycles will clear that light even without disconnecting the battery. So if the codes are still there, it's still doing it.
Old Nov 30, 2009 | 09:42 PM
Pinzer's Avatar
Pinzer
Thanks. The check engine light came on sometime after I replaced the gas cap due to a failed emissions test.
I read here that poorly sealing caps can cause the light to come on, so I put another new cap on as well. I'll check the PCV hoses too.
Old Jan 3, 2010 | 08:55 PM
Pinzer's Avatar
Pinzer
Hey Krewat,
or anybody else. The PCV line has some sort of insulating rubber foam hose over it. At least I'm assuming that that's not the actual PCV line. The foam is crumbling and disengrating. What's the purpose of the foam? Do I need it? Per Krewat's suggestions below, I want to replace the PCV elbows and hose. Can I get the PCV replacement elbows at Autozone, or can I just eliminate them and use a single hose to the PCV valve?
Thanks!
oldhokie
Escape & Escape Hybrid
Apr 1, 2022 11:34 AM
Mrdbraun
Modular V10 (6.8l)
Feb 8, 2017 09:19 PM
Mrdbraun
May 17, 2016 11:19 AM
calialx1
Apr 24, 2011 11:12 PM
telesquirt
Feb 10, 2009 12:55 PM
