codes
Old Nov 27, 2009 | 03:21 PM
crazymut's Avatar
crazymut
codes
Ok I just had my codes read, I got PO672, P0674, P0676, P0678 glow plug ckt. I also got p0683 GPCM to PCM comm ckt. I am guessing the gpcm is bad. Any other ideas? On the bright side I did not have any codes on my trans. Although that also means that I dont have much direction in what may be wrong with the trans either. It occasionally does not want to shift into second unless I let up on the throttle. It is like it is taking a long time to build enough pressure to shift.
Old Nov 27, 2009 | 06:51 PM
F350-6's Avatar
F350-6
Try swapping the plugs on the GPCM and see if the codes jump to the other side. That would confirm it's not a glow plug issue.
Can't help on the tranny issue. Mine shifts into 2nd every time I move the shifter.
Old Nov 27, 2009 | 07:35 PM
bfife's Avatar
bfife
still plays with trucks
I'm not familiar enough with the California models. I know they use a different control unit than the other 49 states. moduel vs solenoid.
Barney
Roody727
Jan 25, 2013 06:43 PM
Gary F-250
Dec 9, 2012 02:44 PM
Gruntface
Apr 30, 2012 05:37 PM
sdsd
Oct 9, 2010 04:17 PM
beezf350
Oct 22, 2009 07:52 PM
