carburetor leaking / flooding
Old Nov 27, 2009 | 11:34 AM
photom17's Avatar
photom17
the single barrel carburetor on my 1980 f100 just recently started leaking quite a lot of fuel from somewhere near the bottom . . . it started after having some work done at a local garage - new clutch and new catalytic convertor and piping and also replacement of some of the vacuum hoses on the carb itself . . . could it be just something out of adjustment on the carb? . . . oh, and the carb is a rebuilt and has been on the truck for over a year with no leak problems till now
Old Nov 27, 2009 | 04:33 PM
Franklin2's Avatar
Franklin2
Does it run ok or is it running rough? If it's running rough, look down the carb with a flashlight with the engine running. If you see liquid fuel dripping down in the carb throat, the float level is too high and there is probably a chunk of dirt under the float needle. If they replaced one of the fuel lines, it may just be a little chunk of rubber from the hose.
KsCop
Dec 24, 2013 08:09 PM
LARIAT 85
Jun 10, 2012 06:40 AM
TedR56
Jul 25, 2011 01:20 PM
jsalty
Sep 10, 2009 05:42 PM
F2fan
Sep 13, 2003 02:42 PM
