What causes the romps?
Old Nov 27, 2009 | 08:14 PM
tdpower's Avatar
tdpower
re
Originally Posted by SpringerPop
I'd say it's caused by the speed of the software's feedback loop. Under normal oil viscosity conditions, the software is slow enough to just regulate the pressure, but when the oil is thicker, the software is too fast for the conditions, and the pressures undershoot, and the loop isn't stable and out of control.
Pop
I'm wonder if they made software changes to the pcm in later years. Maybe a poll would be in order to find out what years are commonly affected.
Old Nov 27, 2009 | 09:55 PM
SuperDoodie's Avatar
SuperDoodie
Seems like it has something to do with the resivour staying full of oil.
Old Nov 27, 2009 | 10:29 PM
tdpower's Avatar
tdpower
re
That could be....My only thought what would be the difference between syn. and dino in that case? There is a check valve in there. I can see the lighter oil flowing better.
Old Nov 27, 2009 | 10:42 PM
SpringerPop's Avatar
SpringerPop
We know they made software changes over the years, but we don't know if any of it was relative to the HPOP pressure control loop.
Might make an interesting specific survey.
Pop
Old Nov 27, 2009 | 10:52 PM
tdpower's Avatar
tdpower
re
Pop
There is a lot of different variables to consider. I just think the later ones don't have the same problem. Doubt we could get a re-flash out of Ford..Maybe you could do the survey; I don't even know how.........
Old Nov 27, 2009 | 11:11 PM
SpringerPop
I would MUCH prefer to put up with the occasional "romps" than to let Ford anywhere near my data-link port.
No way!
Pop
Old Nov 27, 2009 | 11:19 PM
clux's Avatar
clux
If it's a function of programming, shouldn't aftermarket tunes cure or cause them?
I think it's a IPR/ICP issue, mine disappeared after changing ICP sensors.
Old Nov 27, 2009 | 11:22 PM
tdpower's Avatar
tdpower
re
No way!
Pop
They would probably put a greenhouse carbon tax on it.
Old Nov 27, 2009 | 11:26 PM
SpringerPop
Do we know if aftermarket programming messes with the HPOP pressure control loop?
Pop
Old Nov 27, 2009 | 11:51 PM
tdpower's Avatar
tdpower
re
[quote=clux;8179044]If it's a function of programming, shouldn't aftermarket tunes cure or cause them?
Good question! I would like to hear from the experts as well. Maybe they will chime in.
Old Nov 27, 2009 | 11:53 PM
nhill2090's Avatar
nhill2090
Although I do agree with Dan with software being an issue, I am willing to bet its oil related.
Lets think about this. The system is using high pressure oil, from the engine lube pump, to fire the injector. What happens when that oil is thick and cold? Will it fire correctly? I think not.
Therefore, sythetic oil woudl not be a bandaid as much as a fix to the problem of thick dino oil.
Old Nov 28, 2009 | 12:05 AM
mechelement's Avatar
mechelement
Why does my truck not experience the romps in the low twenties and the OP is experiencing the romps in the low fifties? We're both running 15W40 dino oil. Doesn't sound like an oil issue, sounds like an electrical/mechanical issue. Maybe thinner oil masks the electrical/mechanical issue, IDK.
Old Nov 28, 2009 | 12:13 AM
  #28
tdpower's Avatar
tdpower
re
What you are saying makes total sense to me. Just seems to me that a lot of the newer vehicles don't have this problem. When I told my Dad about the "romps" ; he acted like I had two heads! (He has a 2002 7.3 with 200k)
Old Nov 28, 2009 | 12:17 AM
  #29
binuya's Avatar
binuya
For me, the installation of an HPX line has nearly eliminated the romps. Before that I would see occasional romps in the low 50's, and fairly regularly in the low 40's. I run Delo 400.
Old Nov 28, 2009 | 12:24 AM
  #30
tdpower's Avatar
tdpower
re
Try rotella 5/40 syn. and you can run it all year long.
