Bearing Replacement
Old Nov 26, 2009 | 05:00 PM
eprn1n2's Avatar
eprn1n2
Bearing Replacement
The truck pulls to the right so we took it in to have it aligned. We were told to have the bearings replaced. The only thing that seems odd is that the axle has 60000 miles on it. It seems low for the bearings to be going. What is the test to see if they need replacing?
Old Nov 26, 2009 | 08:15 PM
gearloose1's Avatar
gearloose1
1. if it was driven in deep water
2. damaged from improper installation / repacking
3. bad luck...
Groaning sound is the normal warning of bad bearings.
Old Nov 26, 2009 | 08:38 PM
eprn1n2's Avatar
eprn1n2
I put the whole axle on last year so the history is unknown. It was certified to have 50000 miles on it and that is all I know. No groaning.
Old Nov 27, 2009 | 08:48 AM
texans's Avatar
texans
Jack up the front of the truck and set it on jack stands. Then try to move the tire up and down with a pry bar. You shouldn't see play there. Also try move back and fourth side to side and any other direction. That is the best way to find bad suspension parts and so fourth. It helps to have someone help you so one can move the tire while the other one watches for play. Do both sides.
Old Nov 27, 2009 | 07:57 PM
eprn1n2's Avatar
eprn1n2
Thanks Scottie
Pkupman82
Offroad & 4x4
Jan 30, 2011 09:22 AM
garyh8
Feb 10, 2008 07:39 PM
doctorolds
19
Jul 13, 2007 12:22 PM
brnc
Bronco II
Feb 3, 2003 08:21 PM
