Gear selection help!!
Old Nov 26, 2009 | 12:22 PM
emmagator's Avatar
emmagator
Ok i have 2006 F350 8" lift. I will be running 37" tires for the time being but might go up to 38" later. My question is, if i put in 4.56 gears and never end up going to a 38" tire will it be too low? Or will it be acceptable?
Thanks, DB
Old Dec 1, 2009 | 10:22 PM
emmagator's Avatar
emmagator
nobody has any advice?
Old Dec 1, 2009 | 10:31 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I think 4.10 or 4.30 would be a better choice unless you're doing some very heavy towing.
Old Dec 1, 2009 | 10:48 PM
jlmotox's Avatar
jlmotox
once I get the $$$ I am going to get 37" tires and 4.56 gears...I tow and don't have a long commute to work, if you don't tow or don't go with 38" tires 4.30 gears will probably be better for your mileage...
Old Dec 2, 2009 | 11:50 AM
emmagator's Avatar
emmagator
I tow about 9k 6 to 10 times a year. I just dont want to regret my decision. Mileage is fairly important, right now i get between 14-15 mpg.
Old Dec 2, 2009 | 01:22 PM
Toreador_Diesel's Avatar
Toreador_Diesel
4.56 gears will get you back to 3.73 with your 38s, but if you plan on staying with 37s, 4.30s are the gear of choice.
