Sponsored by: Real Truck
axle problem
Old Nov 26, 2009 | 07:15 AM
camperf350's Avatar
camperf350
axle problem
i have a 2001 f-350 , srw, 4x4, 7.3, D1 , 3.73 ratio limited slip axle.
i pull a 8000lb fifth wheel camper, when pulling on turns the rear end chatters really bad, i had ford change the oil 2 times and still have the problem that is getting worst, what can i do?
Old Nov 26, 2009 | 07:20 AM
SGnAZ's Avatar
SGnAZ
Sounds like you need to add some more friction modifier.
Old Nov 26, 2009 | 07:51 AM
scootyg69's Avatar
scootyg69
friction modifier if it's not to late.......
Old Nov 26, 2009 | 07:53 AM
camperf350's Avatar
camperf350
i would like to change the oil my self, any suggestion on what oil i should use and friction modifer?
Old Nov 26, 2009 | 07:58 AM
camperf350's Avatar
camperf350
if is to late what is my next step, other than a dealer ship, i have had this problem from day one and is getting worse.
Old Nov 26, 2009 | 08:03 AM
scootyg69's Avatar
scootyg69
if the limited slip clutches are worn out then the carrier has to be removed to replace them, if you are a good back yard mechanic with the gauges it can be done, you can find all the specs online, as for the gear oil, a good synthetic, like amsoil, mobile 1, they also sell the friction modifier. I've had good luck with both of them.
Old Nov 26, 2009 | 08:06 AM
SGnAZ's Avatar
SGnAZ
Welcome to guzzle's Rear Differential Maintenance Web Page
Old Nov 26, 2009 | 08:24 AM
SGnAZ's Avatar
SGnAZ
https://www.ford-trucks.com/forums/9...for-diffs.html
Some more good reading
Old Nov 26, 2009 | 09:26 AM
camperf350's Avatar
camperf350
good info on the readings, i think i will change it my self .
i install mag- tech cover , last time i had it change ford installed 6 quarts of 75w-140 and 2 - 4 oz additive lubricant, my question is can i use 75w-140 royal purple synthetic and a better after market additive and how much additive should i add?
Old Nov 26, 2009 | 10:32 AM
camperf350's Avatar
camperf350
does this sound right no additive, see below from royal purple.
Richard,
F350 could come with several different rear ends.
A Dana 80 Limited Slip – RP MaxGear 75W90 – 4.25 quarts
A Ford Factory Limited Slip – Rp MaxGear 75W140 – 3.5 quarts
No additive is needed in either oil as both already come fully formulated.
Have a safe Thanksgiving Holiday.
David
David Canitz
Tech Services
Royal Purple Inc.
1 Royal Purple lane
Porter, TX 77365
281.354.8600
713.725.7207 cell
dcanitz@royalpurple.com
Old Nov 26, 2009 | 10:46 AM
GUNNERDOG's Avatar
GUNNERDOG
Stock the ford sterling 10.5 should take 3.5qts 75w140 with 4oz XL-3 friction modifier...If you bought a new cover with a 6qt capacity and only put 2-4 oz of friction modifier in it then you put less than 50% the amount of friction modifier required. This is probably your problem. I just hope it isn't too late for your LS clutch.
Royal purple comes with additive already in it... some do and some don't, so read the sticker on the container carefully and CHECK EVERY BOTTLE YOU BUY... Once i bought the mobile 1 stuff and got it home only to discover i had grabbed 2 bottles with modifier in it and 2 without...
Now I use the royal purple without adding any additional friction modifier and I don't have chatter...
