i have a 2001 f-350 , srw, 4x4, 7.3, D1 , 3.73 ratio limited slip axle.
i pull a 8000lb fifth wheel camper, when pulling on turns the rear end chatters really bad, i had ford change the oil 2 times and still have the problem that is getting worst, what can i do?
Looks like you are getting some help in the tech forums. Hopefully they will get you fixed up and your problem solved. Look around the site and be sure to checkout your state chapter in your wanderings: Georgia Chapter - Ford Truck Enthusiasts Forums
i hope this works , i ordered some royal purple 75w140 for the rear and the front and a mag tech cover for the front, it should be here in about 8 days. thanks for the help.
