Over Cab Lights
Old Nov 26, 2009 | 11:59 AM
MustangMatt96GT's Avatar
MustangMatt96GT
I used the factory plug... still works to this day.
Old Nov 26, 2009 | 02:11 PM
nsandhuiii's Avatar
nsandhuiii
Sorry
Guys,
I am very sorry about the whole drinking and driving stuff, it is insensitive and not appropriate. In addition as a new member of this fraternity, I do not want to start off on a bad note. I hope everyone has a great Thanksgiving. I will be posting pictures of my truck in the am. Take care.
N. S. III
Old Nov 26, 2009 | 06:35 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Originally Posted by 95_Dually
This is a sore subject for me. Drink and drive and you should be punished to the full extent of the law, PERIOD. When you lose a family member to a selfish idiot like that then you too will understand.
Never had a Family member killed, but many of my uncles on my dads side are drunkards, so I back up Daully, fully, till the end of time. No ifs, ands, or butts. There *** should be thrown in jail. As for the cab light thing, I will remember that when I got to install some in the 250.
Old Nov 26, 2009 | 09:31 PM
97oneton's Avatar
97oneton
Originally Posted by Brain's 97 Diesel
To nsandhuiii: Pull the passenger side kick panel off below the dash. there is a two wire plug, black & brown wires I believe. this is the "feed" for the roof/cab lights. It is already fused and hot when the parking lights/head lights are turned on. check it with a test ligh to be sure. find a match to this plug (Pep Boys/Auto Zone/etc) and wire your lights in here, or cut the factory plug off and make your own connector.
this is the easiest way.
Old Nov 27, 2009 | 11:22 AM
SF-ESS's Avatar
SF-ESS
now that we know this tidbit of knowledge, does anyone know where to find a template for proper placement, i have seen 2 different setups the (o o o o o) and the (o ooo o) so which is right?
Old Nov 27, 2009 | 11:32 AM
97oneton's Avatar
97oneton
o o o o o is how the factory does it o ooo o is how garbage motors does.not sure if ther is a templet,find an obs and measure it or later today i can measure mine if that helps you
Old Nov 27, 2009 | 12:16 PM
MissIndependent's Avatar
MissIndependent
i did all 5 of mine evenly spaced cuz that's what i like- that's just personal preference though. there's no reason not to go three in the middle and two further out iffin you don't mind that's how chevy does it.
i used my sister's dodge to get approximate measurements for the placement and then marked it on my truck and set all the light up there to make sure i liked it. then i re-measured about a half dozen times before i started drilling! i can measure in a little while...gotta go out and measure a horse for a blanket anyway.
i used a pacer kit and it came with a separate switch that you were supposed to connect all the positives to, but i just used a butt connector to splice right into the brown wire under the pass. kick panel and they come on with my headlights. oh yes and clear silicone around the edges to help prevent leaks (i've never had a problem)
the one thing i might do differently if i did it over would be to set the lights further back from the windshield to make it easier to fish the (SHORT!) wires out from between the double roof of the cab. that was a royal pain and i have smaller hands than most of yall! there is still a pencil somewhere in there that i lost hold of in the process and never could find...
Old Nov 27, 2009 | 03:29 PM
TheTowingCowboy
Lol thats my goal, is to get that pencil, I want it.
Old Nov 27, 2009 | 05:09 PM
SF-ESS's Avatar
SF-ESS
Not trying to , just been wanting to do the lights since i got the truck, as well. MissI your measurements would be great, when you get around to it. ill see if i can find how far back stock ones go.
Old Nov 27, 2009 | 06:12 PM
scatgo's Avatar
scatgo
Originally Posted by nsandhuiii
First of all, please no jokes about my limited mechanical ability. Ok, just laugh. But if you need some good legal advice.... Alright, so I have installed the over cab lights on my 1997 F250 HD and have got power to them if I run the wire with the fuse to the battery and then to the switch (yes it works) however, how do I run the wire to the fuse box so that they will only come on when the headlights come on? It seems that right now, I have a continues source of power from the battery to the switch and thus it will eventually drain the battery. Ok, laugh all you want but when I take out the #4 fuse, the headlights still work, so what is up?
nsandhuiii
Now that you have cab lights if you ever have water dripping from just above the top of your windshield after it rains its the cab light that are leaking not the wind shield.
Old Nov 27, 2009 | 07:10 PM
nsandhuiii's Avatar
nsandhuiii
Got ya
Yeah, the drip thing was not too pleasant. But I did use silicone, used some food coloring with a power washer to make sure that this time everything was H2O tight. By the way I have reviewed the post regarding changing the stock bench seat out with Captain Chairs. Could someone recommend a site that sells reconditioned seats, or am I better off calling around the local junk yards? In addition, is there a place in the Raleigh/ Durham NC area that power stroke owners get together and so stuff, like toy runs and such. With the economy as bad as it is, perhaps doing a little charity for those less fortunate would be in order. Hope everyone had a great Thanksgiving.
N. S. III
Old Nov 27, 2009 | 07:53 PM
97oneton's Avatar
97oneton
N. S. III
look on ebay under 'super duty seats' there is a place in va that sells seats out of all kind of newer vehicles.ford,gm,dodge,etc.hope that helps
Old Nov 27, 2009 | 07:57 PM
  #28
95_Dually's Avatar
95_Dually
nsandhuiii, there is a North Carolina chapter here on FTE. Here is the link https://www.ford-trucks.com/forums/forum88/
Old Nov 28, 2009 | 09:21 PM
  #29
MissIndependent
ha, well u come on down and visit and you can have at it. i personally have no intention of taking down the headliner EVER again. it was a b*tch!!
will do tomorrow...yesterday went by the wayside because my mom's pony didn't want to be caught and my truck didn't want to start. so i spent half the afternoon chasing the pony and the other half under the truck.
knock on wood, i got mine nice, snug, and sealed. i do have a water issue where i cut the third brake light cover to run my cb antenna cable in... :/ i'm thinking some weather stripping is in order...doors all need it anyway
Old Nov 29, 2009 | 08:11 PM
  #30
Oversize's Avatar
Oversize
If you want the factory setup on these trucks they are 8" from the front edge of the light to the edge of the windshield chrome piece, then they spaced 12" apart on centers. So measure your cab across the top find the center and then 12" from mark to mark then put the center of you lights on those marks then a trick I used is when you take the headliner down then front piece of it is metal and has the same curve as the windshield and top of the cab you can use that as a template for the curve. set it on top and meseure the distance at both ends from the front edge and that till give you you forward spacing then the side to side spacing is all that nessasary. Also if you want the traditional spacing rather than the factory even spacing take the number 2 and 4 lights and move them inward 2".
