Sponsored by: Real Truck
4x4, low range
Old Nov 24, 2009 | 06:43 PM
bluetj98's Avatar
bluetj98
Question 4x4, low range
hi everyone i just bought a f250 superduty with a v10 it has 86k on it and today when i was driving home from work the 4x4, and low range light came on then the overdrive "off" light was flashing pulled over turned it off cranked it back up and everything came back on. the truck feels normal shifts right and all just worried about those light flipping out if anyone has any info that would be great thank you.
Old Nov 24, 2009 | 06:58 PM
Tom's Avatar
Tom
Not sure about the low range light, but a flashing O/D light means the PCM thinks there is something wrong with the transmission. There is a transmission trouble code stored in the PCM's memory.
Unfortunately you can't read transmission codes with most scanners. You'll likely have to take it to a Ford dealer to get the codes read and interpreted.
Old Nov 24, 2009 | 07:24 PM
bluetj98's Avatar
bluetj98
thank you im goin to look over the wiring harness and hope for the best for the wallet
Old Nov 24, 2009 | 07:27 PM
senix's Avatar
senix
wonder if autozone could read that code? Don't suppose since it has to do with the tranny..but worth a shot?
Old Nov 24, 2009 | 10:50 PM
firemech's Avatar
firemech
O/D light
I don't know about the low range light but I had the O/D light blinking and Ford told me to service the transmission, I did and everything was ok. When I took off the transmisison oil pan it had never been serviced since it was installed. Found the filter was so dirty it was starving the pump and causing cavitation. You might try that first.
Thanks,
Firemech.
Old Nov 25, 2009 | 02:59 AM
twags6's Avatar
twags6
Probably not but it wouldn't hurt to try. I know it wont work on the 7.3 engines since they weren't OBDII compliant. Maybe somebody near you has an AE scanner or something similar. Those will pull the codes.
Old Nov 25, 2009 | 12:56 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The OD light means the PCM has detected something with the transmission, but with the 4x4 and low range lights, that's all a big bunch of weird.
Any water on the passenger-side floor? Meaning water in the GEM connectors?
Either that, or you have a pinched wiriing harness between the cab and the frame. I found my wiring harness was pinched like that when the truck was new. Glad I found it early.
Old Nov 25, 2009 | 05:06 PM
bluetj98's Avatar
bluetj98
update umm checked the fluid for the trans wow its was not on the stick filled it up lol
and drove it again to day o/d light stops (good) but no its locked in 4high and the low range ans 4x4 lights are still on oh yeah switch is off and nothing happens when i move it around think im goin to the ford dealership after thanksgiving everyone
slomafarms
1997 - 2003 F150
Dec 23, 2015 06:58 PM
nixvet2000
1978 - 1996 Big Bronco
May 20, 2011 12:31 AM
cardboardcamper
Mar 19, 2011 12:54 AM
flaminfordman
Aug 5, 2007 08:51 PM
pcguy760
Feb 9, 2005 06:03 AM
