Did I make out...
Old Nov 24, 2009 | 05:25 PM
SoCalExile's Avatar
SoCalExile
Did I make out...
..on this truck I just bought? Turns out the casting number for the 400M is Casting number is D1AE-A1C (or maybe D1AE-A10). That puts it as a '71, which if I've read right means it does not have the retarded cam, correct?
Pic:
Old Nov 25, 2009 | 12:39 PM
hollenjoe's Avatar
hollenjoe
If its original, you could even have the higher compression pistons, although the cam may be the non retarded one any new aftermarket cam would be way better...
Old Nov 25, 2009 | 07:43 PM
ctubutis's Avatar
ctubutis
According to Bubba's site (M-Block 351M/400 Parts Reference) that casting
was used MY1971-1973.
The Casting ID only represents the family of the component, not the model year(s) the
component was used in.
Check out that guy's site for some useful information on these engines.
Old Nov 25, 2009 | 07:45 PM
danlee's Avatar
danlee
The block casting number only means that the casting is the '71 type casting. You need the date code next to the oil pressure sensor to determine when it was actually built. I believe that the '71 castings were used until at least '73, but the high compression non-retarded motors were only used in LTD sedans in '71.
What transmission is in it? If you are really lucky, it will be an FMX, and the motor will be one of those rare-as-hens-teeth 400s with a SB bell pattern.
Old May 14, 2010 | 10:51 PM
PDX_F250_78's Avatar
PDX_F250_78
I've read a lot on this Bubba guy. Does he still post on this site?
Is this bubbaf250?
Thanks
Old May 14, 2010 | 11:51 PM
maskedman's Avatar
maskedman
It is called Bubba's M Block Workshop.
Old May 15, 2010 | 06:20 AM
danlee's Avatar
danlee
Is this bubbaf250?
Thanks
Bubba's M Block Workshop original site is defunct, but it still exists here:
Old May 15, 2010 | 08:05 AM
firstonraceday's Avatar
firstonraceday
He (Bubbaf250) hasn't posted here in several years. Very knowledgeable in the 335 series engines. I've wondered several times what happened to him.
Old May 15, 2010 | 10:39 AM
PDX_F250_78
He was a mod here, so I'm sure someone knows what happened.
somerandomguy
Mar 14, 2017 11:44 PM
ceetwarrior
85
Apr 7, 2011 07:59 PM
400Nut
Apr 13, 2006 01:55 AM
FEmtnmax
Nov 10, 2005 05:32 AM
Pilch
May 11, 2004 10:31 AM
