Master cylinder blowing up?
Old Nov 22, 2009 | 09:11 PM
MarlinBrad's Avatar
MarlinBrad
Has anyone heard a pop under the hood and opened it and seen brake fluid all over the hood and against the firewall? The cap on the master is on tight and I can't see any leaks anywhere but it's like it has way too much pressure in the system or something. Just added new brake lines in the rear.........do I need to bleed the system a second time maybe?
Old Nov 22, 2009 | 09:24 PM
Mr. Finch's Avatar
Mr. Finch
the only thing I can think of is when a front hose blew on my truck, but after the POP, It was obvious what happened when the brake pedal droped to the floor and the right front wheel started sto smoke alittle from the brake fluid hitting the hot rotor.
But you still have a brake pedal right?
Old Nov 22, 2009 | 09:28 PM
MarlinBrad's Avatar
MarlinBrad
yeah. brakes work fine.
Old Nov 22, 2009 | 09:50 PM
Mr. Finch's Avatar
Mr. Finch
If you have a stick shift with hydrolic clutch, then I would say check that. Thoes are the only 2 systems on the vehicle that use brake fluid, are you sure thats what was spilled everywhere?
Old Nov 22, 2009 | 09:53 PM
Mr. Finch's Avatar
Mr. Finch
How fresh was the brake fluid that you just put in, did it come from a sealed container? Because brake fluid is supposed to be a water free fluid. If water gets in, then it will start to boil from the heat of your brakes, turn into steam and increase pressures, and it can actually "go bad" if it is left open to long, it will obsorb the moisture from the air.
Old Nov 23, 2009 | 08:48 PM
brett12396f150's Avatar
brett12396f150
Did you turn the wheel with the truck off? Sure it wasnt power steering fluid?
Old Nov 23, 2009 | 08:55 PM
MarlinBrad's Avatar
MarlinBrad
Hey Brett12396F150, I was thinking of that today. The fill is pointed in that exact direction and the cover is wet too. Why is it doing that? The pump does wine a little
Old Nov 23, 2009 | 09:18 PM
Chevy 6.2D's Avatar
Chevy 6.2D
If you steer it with engine off mine does this too- I think it's because you are forcing fluid out of the steering sector and into the pump but it's not running so it has nowhere to go but out.
Old Nov 24, 2009 | 07:08 PM
brett12396f150
Yeah, both my trucks do it...its normal....did you turn wheel with engine off? or did it do it while its on?
Herm
Nov 20, 2016 03:55 PM
510econo
Jul 25, 2013 08:28 PM
scooter1986
May 19, 2007 12:00 AM
pockets
15
Feb 19, 2005 07:43 PM
mwc4275
Aug 18, 2002 10:17 PM
