Power Steering Fluid Leak
Old Nov 22, 2009 | 08:06 PM
Kleenax's Avatar
Kleenax
My truck just started leaking power steerig fluid about 2 wks ago, and it seems to come and go. Crawling underneath and having a look, it appears it is coming from the steering gearbox above the pitman arm (I think that's what you call that thing).
Can this seal be sericed/replaced without removing the steering gear, or do you just replace the whole thing?
Old Nov 22, 2009 | 08:14 PM
littlehusky's Avatar
littlehusky
Could be leaking out the side of the flex line when you turn and running onto the box. Get someone to help you...get them to turn the wheel lock to lock while you watch the area.
Old Nov 22, 2009 | 09:06 PM
Kleenax's Avatar
Kleenax
Yea, thanks. I should've done that in the first place; cleaned it off good with GUNK spray, and watched for the leak. Getting forgetful in my old age I guess ;-)
Old Nov 27, 2009 | 08:37 PM
smokey98's Avatar
smokey98
Lucas power steering stop leak worked wonders on mine.
waskin27
General Automotive Discussion
Jun 30, 2013 11:21 PM
grip1968
Apr 30, 2012 09:26 PM
WINGNUT-
1997 - 2003 F150
Feb 14, 2011 08:39 AM
4xfordman
1978 - 1996 Big Bronco
Dec 16, 2001 10:50 PM
