OT Rant! Automatics!
Old Nov 22, 2009 | 06:23 PM
Brown Falcon's Avatar
Brown Falcon
Why must auto transmissions be so freakin messy? They just suck... I hate working on them because there's no way to do it without getting soaked in ATF!
Last time I buy a truck with a Auto if I can help it... that's for sure!
Just brings back bad memories of working on the C6 in my '75 F150 in a gravel driveway. THAT was awesome...
Old Nov 22, 2009 | 06:28 PM
TheTowingCowboy's Avatar
TheTowingCowboy
AMEN, I wish mine was stick, would have been much better, but sticks are hard to find, specially in trucks. But auto's they are so finicky it seems, so messy, bunch of stuff that can go wrong.
2011 Manual Trans?? - Page 5 - Powerstroke Nation
here is a intresting topic thats OT about a OT subject.
Old Nov 22, 2009 | 06:32 PM
helifixer's Avatar
helifixer
put a drain plug in it the first time you take it off. or I guess it would be the next time you take it off.
Old Nov 22, 2009 | 07:50 PM
Brown Falcon
Yeah, a drain plug would be good. Don't have much time to have the truck out of commission, that's all. Need to drive it almost every day.
Old Nov 22, 2009 | 09:51 PM
helifixer's Avatar
helifixer
you can get bolt on drain plugs at most parts stores. you just locate and drill a hole and bolt it through the pan. it is like a 1/2 inch bolt and nut and than has a 1/4 inch hole drilled through it and a plug. It only takes a couple minutes to install when the pan is down for servicing. I put one on my suburban 250,000 miles ago and haven't had any problems with it.
Old Nov 22, 2009 | 10:13 PM
95_Dually's Avatar
95_Dually
Helifixer, as I was reading Brownies rant, that was the first thing that came to mind. I installed my first one on a C4. After that, all of the auto tranny's I owned got one.
Old Nov 22, 2009 | 11:07 PM
strokin'_tatsch's Avatar
strokin'_tatsch
i sure do like my ZF5!!!! no need to rebuild just becuase i got a chip and injectors or a turbo.. haha. just a clutch!!
i have seen those drain plugs. would be a good thing to do for sure. i thankfully don't have any auto trucks to mess with so i don't need to worry about this. hahaha
Old Nov 22, 2009 | 11:44 PM
wheelie31's Avatar
wheelie31
I cant stand automatic's. I never owned and auto car or truck in my whole life thats counting over 15 cars and trucks,Manual just makes u feel in control, I wont have to worry abt ford not making them anymore till another 15 years when ill be in the market for a 2011 truck!
Old Nov 22, 2009 | 11:53 PM
blue66tang95f150's Avatar
blue66tang95f150
Yeah, manuals have there problems too. Mine grinds downshifting into third and 2nd, and grinds up-shifting if you shift to fast. One of these days when I have some time, I will tear it out and get it all fixed up.
Old Nov 22, 2009 | 11:59 PM
strokin'_tatsch
yeah but my manual has 299,000 miles on it now and hasn't been rebuilt. hahaha. it will need it soon though. its starting to grind every now and then going into 3rd quickly. at that time i will be dropping some major coin on my ZF5 i'm thinkin for stronger shafts.
Old Nov 23, 2009 | 12:02 AM
wheelie31's Avatar
wheelie31
I think thats a common problem in ford manuals both my f350 and 450 have syncro problems in 1st and 2nd gear but mine are dump trucks so there taking a beating, I just live with the grinding or i just gotta find the right rpm so it dont grind.
Old Nov 23, 2009 | 07:11 AM
MADVAN's Avatar
MADVAN
No reason to pull the pan to change fluid.
Just pump it out from the trans cooler.
From around year 99? you cannot even drain the tc anymore.
Bill
Old Nov 23, 2009 | 08:36 AM
blue66tang95f150
How about my buddies Tacoma, its a closed system so you cant even check the level, pathetic I am impressed how simple his truck is under the hood. You pop the hood of any American new truck, its a disaster. His Tacoma was still pretty simple. You could actually see the engine still .
Old Nov 23, 2009 | 01:30 PM
strokin'_tatsch
my buddy's '09 F150 4.6L v8 is pretty simple. popped the hood on it the other day and was rather surprised. i'm not a fan of the modular engines, but it was more simple than i thought it would be. i think i could work on it fairly easily.
Old Nov 23, 2009 | 02:37 PM
Brown Falcon
Yeah. The 4.6's aren't bad to work on. Just hard to reach some things.
I had to pull the pan to change out my Accumulator Body and didn't have any help at all...
