ignernt painting question
Old Nov 22, 2009 | 05:01 PM
jniolon's Avatar
jniolon
old and in the way
getting some pieces of 'stuff' ready for paint... suspension parts, misc frame parts...
driveshaft ??? do you go ahead and paint the u-joints/yoke or just tape it off and paint the shaft portion ??? I've never noticed if they were completely painted or not ???
john
Old Nov 22, 2009 | 06:10 PM
WALFORD'S 56's Avatar
WALFORD'S 56
I generally paint the driveshaft but mask the collar where u-joints slip in and the yoke where it slips in trans.
This is to make installing the new parts easier than cleaning off the paint.
I do not think it would hurt to spray the ujoint.....but may look better if you mask them....Bill
Old Nov 22, 2009 | 06:13 PM
1976F250HiBoy's Avatar
1976F250HiBoy
like walford said, tape off anything that inserts into something else, otherwise the outside diameter will be just thousandths larger and wont slide in properly without removing the paint anyway.
Old Nov 22, 2009 | 06:14 PM
Old F1's Avatar
Old F1
I don’t think the u-joints care if they are painted or not, the slip yoke where is goes into the seal might?
Old Nov 22, 2009 | 07:43 PM
jniolon's Avatar
jniolon
old and in the way
that's what I figured... the trans end is a slip joint and won't get paint but the rear end is a flanged fitting that butts up to a plate on the diff. I think that will get paint and I'll just scrape the faces clean...
movin along slowly
john
Old Nov 22, 2009 | 07:46 PM
Julies Cool F1's Avatar
Julies Cool F1
Have you considered getting the drive shaft powder coated? It takes a lot of abuse!
Old Nov 22, 2009 | 07:54 PM
1976F250HiBoy
if ur truck is anything like mine, powder coating is way too expensive considering the truck shucks the dag gone things left and right. my truck is a torque monster and will either pull what ur hooked up to or shuck the shaft.
Old Nov 22, 2009 | 09:25 PM
jniolon's Avatar
jniolon
old and in the way
nah Julie... p.c. is too expensive for one piece, have to disassemble it (I hate taking u-joints apart) and would take too long to turn it around... I'm going with same color as frame on this piece...
john
