High Idle Potentiometer ?
Old Nov 22, 2009 | 11:44 AM
AndeyHall's Avatar
AndeyHall
I have done my high idle mod exactly to the specs in the tech files, with the switch and the relay. But if I wanted to throw a potentiometer in the mix so that I can control my idle speed, what changes would I need to make? Wouldn't it Be fairly simple? Would I need to buy all of the resistors as described in the 7.3 write-up to calibrate the top end and bottom end idle speed?
