run truck without intercooler pipes
Old Nov 21, 2009 | 11:52 AM
frdf250's Avatar
frdf250
i am in the middle of 2 projects right now. getting my bed back on and painting my intercooler pipes.
i have 4 guyscoming over to help me lift my bed back on,
can i move the truck about 20 feet without having the intercooler pipes attached???
thanks for all the help!
Old Nov 21, 2009 | 11:54 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Yes, it will be just fine.
Old Nov 21, 2009 | 11:57 AM
frdf250's Avatar
frdf250
thanks clay!
Old Nov 21, 2009 | 01:45 PM
agg_bagg's Avatar
agg_bagg
ya like he said it won't hurt anything. you just have to keep the dust down because you won't have a air filter hooked up any more.
Old Nov 21, 2009 | 05:38 PM
sideshow's Avatar
sideshow
yeah no problem. actually I had a boot blow off my dad's 6.0 one day, and after three unsuccessful attempts to clean and tighten it back down (couldn't drive 10 feet without it blowing off again) I limped it back home about 3 miles. took a while to get to speed, but once up to speed there was no difference. was kinda sweating the no filter thing, but I was alone, getting dark, and soaked with sweat from screwing around with it, and took my chances. I've never had one blow off on my truck though. I thought I had blown a tire when it happened, since he had a nail in one tire, and I just plugged it. nothing worse than crawling on top of a hot motor on the side of the road, in 95 degree heat to boot.
Old Nov 22, 2009 | 08:40 PM
jdecker88's Avatar
jdecker88
Actually we have a buddy and member here that is actually running no IC on his 7.3L just ran a delete pipe around and runs fine , so thats no big deal . Just make sure nothing gets sucked into it.
Old Nov 22, 2009 | 08:52 PM
stroken's Avatar
stroken
Running pipes and no IC is different then no IC pipes, you still have all your boost and such, just higher EGT's. Not running anny pipes wont make boost, High EGT's poor driving conditions, but will be okay to run, wouldnt make it a habbit though
