Heater control valve
Old Nov 20, 2009 | 07:46 PM
tbm3fan's Avatar
tbm3fan
Probably could be anywhere along the hose but where "exactly" would have the water control valve for the heater been placed. Before the bracket holding the two hoses on the inner apron or after the bracket?
Old Nov 21, 2009 | 01:35 AM
flipklos's Avatar
flipklos
My 64 has it mounted on the top of the Psg side fender. What is an apron?
Old Nov 21, 2009 | 01:50 AM
tbm3fan's Avatar
tbm3fan
Older picture but what some call an inner fender is what I call the inner apron and that is right where the heater hose bracket can be seen.
Old Nov 21, 2009 | 09:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C3UZ18495A .. Fresh Air Heater Control Valve Cable Operated (Motorcraft YG133) / Available from Ford.
Since this valve is cable operated, the end of the cable determines where the valve is spliced into the heater hose. It has nothing to do with the bracket for the hoses.
The re-circulating heater's shut-off valve is not cable operated. So...it can be mounted before/after the bracket.
flipklos: Inner fenders are refered to as fender aprons.
Old Nov 15, 2010 | 08:07 PM
LARIAT 85's Avatar
LARIAT 85
(I did a search)
I really like that heater hose bracket. Is that an original Ford piece? If so, what years can I find this?
Old Nov 15, 2010 | 10:45 PM
OldHarley's Avatar
OldHarley
Mike,
Pretty clear picture of it at this thread. BossF100 posted a few of a truck he found.
https://www.ford-trucks.com/forums/1...f-100-a-2.html
Old Nov 16, 2010 | 10:54 AM
macgiobuin's Avatar
macgiobuin
My manual valve is roughly 2-3 inches closer to the firewall than your apron bracket.
Old Nov 16, 2010 | 04:32 PM
tbm3fan's Avatar
tbm3fan
I have already placed the control valve... back in November 2009. Old thread brought up by Lariat 85 asking about the heater hose bracket on my truck.
Old Nov 16, 2010 | 07:04 PM
LARIAT 85's Avatar
LARIAT 85
No one knows where I can find a heater hose bracket like the one shown in the pic?
Old Nov 16, 2010 | 07:26 PM
66crawler's Avatar
66crawler
Make one lol.
Old Nov 16, 2010 | 08:05 PM
LARIAT 85's Avatar
LARIAT 85
Thank you, Captain Obvious.
That didn't answer my question, did it?
Old Nov 16, 2010 | 11:19 PM
tbm3fan's Avatar
tbm3fan
Unless NumberDummy chimes in then you are probably out of luck. Never seen one aftermarket. That means out of a junkyard if still on the fender apron or a NOS one that has yet to be sold. Of course that requires the part number and I am not that skilled at locating it yet...
Old Nov 17, 2010 | 01:28 PM
Boss9F100's Avatar
Boss9F100
They are pretty simple to find if you look.
Old Nov 17, 2010 | 01:34 PM
Boss9F100's Avatar
Boss9F100
I have had 4 trucks with the valve and all pretty much in same location
Old Nov 17, 2010 | 02:00 PM
LARIAT 85's Avatar
LARIAT 85
Was that comment supposed to help me, Boss9F100?
If that is the best answer you could come up with, you should have just ignored my question.
I have a 7th generation 1985 F150, so I am not as familiar with the 1961-1966 trucks. I have been a steady customer at the country junkyard in my area that has 90% Fords from the late sixties on up, and I have never seen a bracket that looked like that one.
I also looked at Summit and Jegs, and they don't offer one that looked like that, either. Even did a google search, and still no luck.
