Old School DPTuner Chip
Old Nov 20, 2009 | 01:08 PM
PwerStroke99's Avatar
PwerStroke99
Old Nov 20, 2009 | 01:32 PM
Izzy351's Avatar
Izzy351
No, but other tuners can put tunes on the chip. Is it a six position? Tony Wildman will fill it for $150...
Old Nov 20, 2009 | 01:51 PM
4inchlovin's Avatar
4inchlovin
Speaking of newbies You cannot post for sale item in this forum...
You can post it in the classifieds and then put a link to it here... Please edit your post.
Old Nov 20, 2009 | 01:55 PM
PwerStroke99
Thanks Nolan. Yes it is a 6 pos chip Joe
Old Nov 20, 2009 | 01:59 PM
4inchlovin's Avatar
4inchlovin
no prob bob! Dont wantcha gettin in trouble...
Old Nov 20, 2009 | 02:01 PM
PwerStroke99
Thanks again. Fixed!
Old Nov 20, 2009 | 02:05 PM
Robert6401's Avatar
Robert6401
ok, so I have been waiting for something like this to come along. My question is, how do I check my PCM code to see if it will work for me?
Old Nov 20, 2009 | 02:13 PM
4inchlovin's Avatar
4inchlovin
It is on the back of your PCM... You PCM is located next to your left foot under the e-brake pedal
Old Nov 20, 2009 | 02:18 PM
PwerStroke99
You will have to remove the PCM to check the code. there is a 10mm hex head bolt under the master cylinder you will need to remove from the wiring. it will be closest to the fender.
FYI, these tunes are 5 years old. So if you want updated tunes, you will have to have a different tuner do this for u.
Old Nov 20, 2009 | 02:20 PM
PwerStroke99
DP-Tuner » Installation Instructions
Half way down is the instructions for PCM Code location
Old Nov 20, 2009 | 02:21 PM
guzzle92's Avatar
guzzle92
If you have it re-burned by PHP to TW, the code does not matter. You will need to know your PCM code for them to burn it though......
Old Nov 21, 2009 | 06:29 AM
F350-6's Avatar
F350-6
It may not be considered fashionable by some, but I'm pretty sure Jody will reburn it to match a new PCM code as well. They don't push the 6 pos switch, but I believe they still offer and service them.
Old Nov 21, 2009 | 08:10 AM
Izzy351's Avatar
Izzy351
Shop around though. Tony will fill it up for $150. What's that, $25 a tune? Don't know if the others do that or not.
Old Nov 21, 2009 | 08:24 AM
F350-6's Avatar
F350-6
And then he'll keep reburning it for free as you dump more and more mods under the hood, right Joe
Old Nov 21, 2009 | 10:22 AM
Izzy351's Avatar
Izzy351
Yep... I got six new tunes when I put my hybrids in.
